Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
New dyno after 3.5 swap
Old Apr 1, 2006 | 06:00 PM
96sleeper's Avatar
Here are the new numbers. The graph shows my best 3.0 dyno versus the new 3.5 dyno. The low range torque is low I believe because of the high lift cams and lack of variable cam timing. Also I disabled the 2k2 variable intake manifold which hurts low end some also. The 2k2 manifold definately doesn't hold power like a MEVI at high rpm, even with the cams.
Changes since last dyno (shown):
VQ35DE engine with VQ30 timing equipment (no variable cam timing)
JWT VQ35DE knockoff cams (260 duration, 10.9mm lift)
additional power mods:
JWT VQ30DE ECU with 7000 rpm redline
SAFC-II (tuned to 13:1)
JWT short ram intake
70mm ported pathfinder TB
Cattman headers
2.5 inch test pipe with 2.5 cutout
2.5 inch exhaust(dyno numbers posted will be open cutout)
Old Apr 1, 2006 | 06:15 PM
Nismo3112's Avatar
Custom User Title
Wow, those numbers are terrific!! Makes me want to get a set of cams and tune my car
Old Apr 1, 2006 | 09:15 PM
AsthmaMax11's Avatar
holy hell those are some sick #'s.
I believe that is about where Jay25 was when he had supercharged his max for the first go around. (same dyno btw)
I predict a 13.2@106 at Steele
let me know when you are going
Old Apr 1, 2006 | 09:21 PM
THT's Avatar
THT
Throbbing member
Sweet Jesus Mary and Joseph...I can't wait until next March when I get my bonus check...3.5L w/ cams is the plan!
Old Apr 1, 2006 | 09:47 PM
Zack342's Avatar
DAMN DAMN DAMN your well over 300bhp at the crank. Hell i think your doing better than most of the guys with 3.5's in their car from the factory
Edited and corrected
Old Apr 2, 2006 | 12:12 AM
Nismo3112's Avatar
Custom User Title
Originally Posted by zack342
DAMN DAMN DAMN your well over 300whp at the crank. Hell i think your doing better than most of the guys with 3.5's in their car from the factory
There is no such thing as whp at the crank.
Usually a modified engine produces more power than a stock factory engine
Old Apr 2, 2006 | 06:31 AM
Zack342's Avatar
I thought guys with modded 3.5's was implied. I thought Sr20DEn was t he highest at like 269whp or something?
Old Apr 2, 2006 | 07:05 AM
aznsap's Avatar
Cattman headers
wow, nice numbers! did you do the swap yourself? this makes it look tempting, but there's nothing wrong w/ my 3.0 that would give me an excuse to swap it out right now.
and did you have any problems tuning w/ the AFC along w/ the JWT ecu? I've heard people have problems because of JWT's maps.
Old Apr 2, 2006 | 07:16 AM
4DRSpeed's Avatar
Project Ruby......
Holy crap!!! Man I need to do this soon!
Old Apr 2, 2006 | 08:45 AM
Kevlo911's Avatar
Kevlo for President
Damn I wonder what my good ole 30 could do with a good set of cams and a manual.
But nice numbers man.
Old Apr 2, 2006 | 09:44 AM
MDeezy's Avatar
Great numbers. I wonder how much more power the cams added?
Old Apr 2, 2006 | 09:55 AM
Brushedpewter's Avatar
Get rid of the crappy JWT ecu and get yourself a EU.
Old Apr 2, 2006 | 12:00 PM
Weimar Ben's Avatar
Helicopters! Money!!!
nice numbers! If you get a 350z IM, you'll probably dyno higher than SR20DEN.
Old Apr 2, 2006 | 12:14 PM
Nismo3112's Avatar
Custom User Title
It would definitely bump it up past 270whp.
Old Apr 2, 2006 | 12:33 PM
95 maxima se's Avatar
Silver Tooth S2K 9k FTMFW
sick #'s!!!
Old Apr 2, 2006 | 12:52 PM
chris'smax's Avatar
looks good, are you still using stock valve springs?
Old Apr 2, 2006 | 12:56 PM
Weimar Ben's Avatar
You're supposed to use the stock valve springs with those cams. There's really no reason to get stiffer valve springs since the VQ35 can't rev very high anyways. Even if you get upgraded rod bolts, I believe the maximum you want to take a VQ35 to would be 7200-7500rpm which wouldn't be enough to introduce valve float. I think there's some people running the VQ30 at 8000rpm with the stock valve springs.
Old Apr 2, 2006 | 01:05 PM
chris'smax's Avatar
welll i was wondering since i am running nismo cams in mine and i may want to increase the rev limit using EU down the road
Old Apr 2, 2006 | 02:21 PM
96sleeper's Avatar
Yes,
I knew I would not be revving very high with this engine. It just doesn't like it near as much as the old 3.0. Technosquare increases the 350z revlimit to 7100rpm, so I figured I would be fine at a maximum of 7000rpm. I don't suspect the valve springs with last 200k mikes with that much lift from the cams, but it ought to be fine for a long time.
I have no desire to dyno more than him. His dyno is not very realistic to compare to since there is no one else that high with an altima or maxima.
My dyno numbers include full accessories. I did not remove power steering or A/C when I did the swap. I kept the same spark plugs that were in the engine when I got it from the junkyard. I just wanted to go and get it tuned since I knew I was running rich. I did not go just for numbers to brag about.
Old Apr 3, 2006 | 10:59 AM
nismology's Avatar
No you're not. These are a knock-off of the JWT S1 cams and they recommend upgrading the valvesprings.
You're forgetting something. Because of the higher valve lift the valve has to travel farther up and down in the same amount of time. This higher valve speed requires a stiffer spring.
Old Apr 3, 2006 | 11:30 AM
96sleeper's Avatar
Actually I talked to JWT, and this is straight off their website:
Includes 24 springs and shims for use with JWT race cams or JWT street cams with rev. limit raised above 7000 rpm
They said I did not need to replace the valve springs with my rev-limit at 7000rpm.
Old Apr 3, 2006 | 11:34 AM
nismology's Avatar
I thought you were going to rev higher than that.
Old Apr 3, 2006 | 11:40 AM
Weimar Ben's Avatar
http://cgi.ebay.com/ebaymotors/CAMS-...spagenameZWDVW
Here's the ebay listing for these cams. It specifically says not upgrade the valve springs.
Old Apr 3, 2006 | 11:47 AM
nismology's Avatar
I've had dialogue with the original seller of these cams via nissanforums.com before. Stock valve springs CAN be used, but are not required.
Old Apr 3, 2006 | 12:15 PM
96sleeper's Avatar
I think what it means is that the listed cold valve lash range is required to use stock valve springs and it is written like they are two separate lines.
Old Apr 3, 2006 | 04:22 PM
4DRSpeed's Avatar
Project Ruby......
Wow one helluva price for those cams. Damn, I would love to get a 3.5 right now. Hopefully after school.
Old Apr 3, 2006 | 06:15 PM
diymaximakid's Avatar
hey did those cams come drilled for both vq30 and vq35 or did you have to send them out?
Old Apr 3, 2006 | 06:24 PM
96sleeper's Avatar
They have to be drilled.
Old Apr 4, 2006 | 05:02 AM
nupe500's Avatar
Jedi Knight
Very nice #'s.......
Old Apr 4, 2006 | 07:31 PM
JClaw's Avatar
SR20DEN trapped 108 mph at 3150 lbs raceweight (with him in it). He had 263whp.
How much does your car weigh?
Easy 12's on slicks. Emphasis on "easy".
Old Apr 4, 2006 | 10:12 PM
nismology's Avatar
Eh...hold your horses. While it's true his peak numbers are up there with SR20's, the shape of his curve isn't the same due to the lack of VTC's and the stock IM. (See that huge dip in the mid-range? And SR20 made solid HP past redline while this dyno seems to be dropping off fairly quickly.) And if he hasn't done any weight reduction, he won't necessarily be any lighter either. I'm not saying it's impossible, but we should just wait to see how it goes...bench racing is .
Old Apr 5, 2006 | 03:39 AM
96sleeper's Avatar
I really don't want to speculate since I haven't been to the track yet, and I might not even make it before it gets way too hot, but cartest shows me being able to hit a 12.99 on a 2.03 60 ft time. Cartest was right on before, but that just seems hard to beleive to me.
Old Apr 5, 2006 | 06:33 AM
nismology's Avatar
Will you be running slicks or street tires?
Old Apr 5, 2006 | 07:01 AM
Blu's Avatar
Blu
the tits
If you can get the car too hook you will definitely be in the low 13's @ 107-108 on street tires if you're in the sub 3k range race weight. 12's are yours on sticky tires for sure!
Old Apr 5, 2006 | 07:11 AM
96sleeper's Avatar
I only have street tires. I have a buddy with 255/50-16 ET street radials on 16 inch mazda rx-7 wheels, if they will fit.
If I ever meet up with Elon (6spd_hayes) at the track, he has drag radials as well.
If I am close on street tires, I will make sure it happens somehow.
Old Apr 7, 2006 | 01:23 PM
JClaw's Avatar
Well if you ever get slicks, take it from me; get big ones. It got so old to spin 3/4 of the time with the 23's, do yourself a favor and go for 26's or 24.5's right away if you decide to get slicks.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
