Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Wizards second dyno...323 HP
Old Apr 18, 2007 | 09:35 AM
Kinda dissapointed with my results.... I only gained 4hp over my last dyno a year ago. Mods since the last dyno include ceramic coated Cattman Gen 3 headers, and MEVI. I expected about a 15-20hp gain over last year. Looks like I can't go any further w/o more fuel, a tuning device, and a good tune.
I welcome your comments/suggestions. Thanks. James
323 HP, 273 TQ
Performance mods on the 99 CA 5spd:
V2 blower
3.25 pulley
FMU (8:1 disc)
T-rex aux fuel pump
Cattman Gen 3 headers (ceramic coated inside and out)
Test pipe
Cattman catback
Exedy Stage II ceramic clutch
Fidanza flywheel
14 lb Centerline rims
NGK one step colder plugs (gapped at .038)
Reclocked blower with 3" charge piping
Vortech Race BOV
MEVI is actived to open at 5100 rpms via Harlan RPM switch
No filter on blower
Other goodies..
Autometer boost gauge
Autometer fp gauge
Autometer dual intake temp gauge
Innovative Motorpsports LC-1 O2 Wideband kit with XD-16 gauge
Other info:
stock injectors
stock maf
stock ecu
After hitting the recall button on my boost gauge, it read exactly 10psi.
To see last years dyno, click here....
http://forums.maxima.org/showthread....highlight=dyno
To see pics of the dyno day event, click here......
http://forums.maxima.org/showthread.php?t=514758
Old Apr 18, 2007 | 10:01 AM
Stillen Maxima's Avatar
Pay to Play
Damn good numbers!
Old Apr 18, 2007 | 10:04 AM
Kevlo911's Avatar
Kevlo for President
Going MAD LEAN up top, that might explain the low numbers. Tooooo much air and not enough fuel.
Old Apr 18, 2007 | 11:17 AM
cardana24's Avatar
Blown
do you have anything to tune your air fuel? I see the red doted line is around 13:1, where I dyno that is where they normally put your target if you are N/A, but lower/richer if you are boosted. Like Kevlo said if you can add some fuel up top you may gain some good power.
*edit*, I thought you were on the same pulley as I am (3.125), but those are really good numbers for 3.25.
Old Apr 18, 2007 | 12:11 PM
NmexMAX's Avatar
dot dot dot ...
You need to get your AFR in line(i.e, add some fuel)
It's been noted before, but something should be done about it.
Good #'s though.
Old Apr 18, 2007 | 02:15 PM
96sleeper's Avatar
As others have said, you are too lean up top. You probably need Z32 MAF and injectors as well as some sort of fuel adjustment to take out the richness in the middle and fine tune the top end. Also, once you have fuel up top, take the car all the way to redline. I would think peak power would be at or near redline especially with the MEVI.
Old Apr 18, 2007 | 07:30 PM
MaxObesset's Avatar
you runing stock injectors on you setup
Old Apr 19, 2007 | 11:36 PM
Yes, but not for long... just finished soldering the Z32 Maf pigtail on. On deck--> either 410 or 555cc injectors.
dcam0326
Sep 8, 2015 11:02 PM
95Maxi
35
Sep 2, 2015 10:37 AM
Grey00lustre
Detailing
May 17, 2004 08:33 PM
