Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Need advice about Dyno
Old May 8, 2007 | 01:36 PM
Swisscheese's Avatar
I have a 2002 Maxima and im just finishing installing full Cattman Exhaust on it. I feel like its time to Dyno it so I can start watching the Air/Fuel mix. When I go get my car Dyno'd are there any specific things I should do or check while there... other than get a Video Clip(got that covered).
Thanks for any advice.
Old May 8, 2007 | 01:47 PM
NmexMAX's Avatar
dot dot dot ...
A video clip is for 'bling' IMO. It's the data that counts.
If you're going to a dynojet, this might help:
http://forums.maxima.org/showthread....69#post5491269
Old May 8, 2007 | 02:22 PM
ajahearn's Avatar
It would have been better if did a dyno before but you might be able to use older 2002 dyno results. The place who did my dyno testing emailed me PDFs of the results. If you send me email I will send you my results but understand that they were from a couple of years ago (I have both stock and with an intake). The only other pieces of advice not noted in the dynojet thread from above is that you must make sure your front tires are in very good condition and your engine should be warm. Good luck.
Old May 8, 2007 | 06:18 PM
Torgus's Avatar
i'd only worry about a/f ratios after you do the headers. but dynos are good to track performance and to compare it to others who have done the same or similiar mods.
Old May 8, 2007 | 06:23 PM
inspiredbykev's Avatar
You should thank my D***
you should buy and install either a apexi safc-II or vafc-II so then you can tune the a/f after you dyno.
Old May 9, 2007 | 05:02 AM
mist max2000's Avatar
you should do one one with your injen on and one run with your stock airbox or a short ram on,
or just remove the injen all together . . . .
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
