Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
VQ35 Swap+ New Mods= 241WHP 237WTQ
Old Sep 28, 2007 | 09:41 PM
  #41
95BLKMAX's Avatar
Originally Posted by NmexMAX
Hmm since you have access to OBDII stuff, maybe you can log some parameters and see if anything changed. Most namely, MAF parameters.
If anything, you can do a rough observation using the SAFCI.
Ahh, didnt think of this. I'll try it out tomorrow and see what the SAFC says. The OBD2 logger stuff I probably wont have it accessible again until Monday, so we shall see.
Old Sep 30, 2007 | 10:10 AM
  #42
95BLKMAX's Avatar
NMexMax, as i said before, with the air filter on, this SAFC was reading 56.9% max airflow.
Last nite I had a lil fun... 59.8%. Only variation is headers. Not bad! Now its just a matter of getting that OBD2 logger and see WHERE that airflow is going
Old Oct 7, 2007 | 09:23 PM
  #43
Qbridg3's Avatar
Originally Posted by 95BLKMAX
New Mods since the last dyno...
- Jimes "T-stat staying open" Mod- while cruising on a hot day with AC on, engine stays at about 165*F, instead of the previous (stock) 192-195*F. Motor never feels heat-soaked anymore, always super responsive.
How do I do that? I'm interested.
Old Oct 8, 2007 | 09:40 PM
  #44
95BLKMAX's Avatar
and I will gladly direct you to post #29
Old Oct 9, 2007 | 03:24 PM
  #45
hacim105's Avatar
Jime's mod is actually designed for the 4th gen.
But yes, you can use the VQ35 t-stat just fine as well.
Also, I wouldn’t say the Z33 t-stat is THAT much better than the A32/33. It’s only about 6-10*F different. The Z33 has an Aluminum radiator, so that’s what takes care of its cooling issues a little better. Also, is there anyone here who has actually used the Nismo unit? Or is it too cold (156*F IIRC) meaning, the car will take a very long time to reach operating temperature, and we all know what that would mean. My understanding is that is primarily used for boosted applications.
IBnismologysayschangetheradiatortoAlbeforescrewing withthetstat
This is what courtesyparts.com says about the nismo t-stat.
http://www.courtesyparts.com/Merchan...Category_Code=
My only question is, does doing the T-stat mod have the same caution as the nismo t-stat does?
Old Oct 9, 2007 | 03:28 PM
  #46
hacim105's Avatar
lol. The dip looks severe on the graph but if you look at it, its only a drop from 14.0 to 13.5, still within that good range. I do that on purpose, like to keep it a tad bit richer up top (preference). Also, this was a sniffer wideband, and from my experience with this shop, it reads lean by ~.4. So If you see 14.0, its really more like 13.6:1. And I use an SAFC1.
No need for PM, Jime himself had it on a post, I just cant find it. Check it. Remove your water outlet. Notice the plunger from the T-stat goes into a hole at the side of the water outlet neck (you have to have it in your hand to know what Im talkin about). Now seperate the Tstat from the housing (careful it doesnt fly off and catch your eye). Now's when it gets cool, get a drill bit or something, cut it to a length of about ~1/8". smouth out the cut so its nice and flat. Now, insert THAT into the hole on the water oulet, re-isntall the T-stat making sure that the plunger's rod sits level pushing against that part you just added. Once the Tstat is on tight, make sure the plunger isnt at an angle and has no play. If its good, put it back on, enjoy ~20-30*F cooler running motor :-D. Add some water wetter while you're at it. Cheap insurance.
What are you cutting to a length of 1/8"?
Old Oct 9, 2007 | 05:17 PM
  #47
NmexMAX's Avatar
dot dot dot ...
I used a piece of 12GA Cu wire. (Cut to ~ 1/8")
Depends on the 'shim' size. Unless you go too much, you should be fine.
Good reference thread:
http://forums.maxima.org/showthread.php?t=157602
Old Oct 9, 2007 | 06:03 PM
  #48
grey99max's Avatar
LandShark has Cosworth
Here's a pix of the cooler 170*F 350Z thermostat vs the stock 3.5 thermostat - for what it's worth:
http://i48.photobucket.com/albums/f2...d/Dscn2420.jpg
Old Oct 10, 2007 | 12:51 AM
  #49
95BLKMAX's Avatar
Hacim- I cut a drill bit that was about the same thickness as the plunger, lol. And as far as having the warning as the Z T-stat does... I'll find out as the cooler days roll in.
NMexMax- you found the OG thread from Jime on it w00h00!!!
Grey- What are you going to do about that hose outlet next to the eactual water outlet? just cap it and clamp it or what?
Old Oct 10, 2007 | 11:26 AM
  #50
grey99max's Avatar
You got it -it's done. I really 'rigged this one - found a rubber hose the right size, put a short fat bolt covered w/RTV into the hose, put clamps around it, put the hose onto the hose outlet of the Z thermostat, clamped it, and call it good. Look closely at the photo:
http://i48.photobucket.com/albums/f2...d/Dscn2432.jpg
I might still use it, so I left it intact. Also razored off the extra RTV....
Old Oct 10, 2007 | 11:32 AM
  #51
95BLKMAX's Avatar
Boss, thats something that we would have done here, LOL!!! Its not about how it looks... its all about getting it to work
Old Oct 12, 2007 | 06:22 PM
  #52
liqidvenom's Avatar
brotherhood of tq
very nice dyno #'s.....
Old Oct 12, 2007 | 09:39 PM
  #53
95BLKMAX's Avatar
werd thanx mate. Hopefully better numbers soon come
Old Oct 13, 2007 | 01:49 AM
  #54
NmexMAX's Avatar
dot dot dot ...
Lick asz.
Old Oct 13, 2007 | 02:31 AM
  #55
accordingtou's Avatar
VQ30 DE T
Lick asz.
Lmao. Nothing like some "friendly comp"
Old Oct 13, 2007 | 09:18 AM
  #56
95BLKMAX's Avatar
If only the EU was friendly to the coils when using the 5.5gen ECU (Jime had coils burning out when he hooked up the EU after doing the full rewire for 5.5 gen ECU, IIRC- EU does the same thing on the E36s M3s, gotta put some resistors or something inline when hooking up the ignition wires to make it work safely).
Im saying this cus that will be my next big mod, and if NMexMax could get it as well, the friendly competition should get ubber interesting
mclasser
22
Nov 12, 2020 01:58 PM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
