Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Kevin's VQ35DE NA Build Epilogue.. DYNO SLIP
Old Mar 4, 2010 | 11:11 PM
Kgkeen101's Avatar
Old Mar 5, 2010 | 02:42 AM
SleepyMax1's Avatar
Wow that's nasty! How much "roughly" would a build or similar setup like this cost the average Joe? Keep up the good work and keep us posted.
Old Mar 5, 2010 | 04:59 AM
Kgkeen101's Avatar
Old Mar 5, 2010 | 05:54 AM
Kgkeen101's Avatar
Old Mar 5, 2010 | 01:14 PM
505max94se's Avatar
Very nice!
Nice choice on the ecu. I recently decided to get a pro-128 for my current build.
How much did the jenvey itb setup end up costing you?
Old Mar 5, 2010 | 03:37 PM
Kgkeen101's Avatar
Old Mar 5, 2010 | 07:21 PM
NiZMo1o1's Avatar
We did some minor modifcations to the hood to make sure the horns indeed fit,
I will test fit mines on my 6th gen , Thank You Kevin for doing what others were scared to try , hopefully we will see more All Motor guys with ITBs.
315 without breaking a sweat , im sure some more tuning and we gain another 8-9whp
Anyways 3rd Gear is killer, pulls very very very hard !!
(you got me there now until I got boost = D)
Anyways we'll catch up and do some more work
Old Mar 6, 2010 | 04:59 AM
LeGaspardVQ's Avatar
ooooo wee!!! Inspiration.... Loving it.
Old Mar 6, 2010 | 11:39 PM
krazy6's Avatar
Badass! I was thinking about making an all motor VQ drag car.
If you break into the 11s I think that you will be the fastest all motor VQ35 in existence.
I think you should get some custom ground cams from kelford and run some serious lift and duration. Then you could take advantage of those awesome 320cfm heads!
Old Mar 7, 2010 | 06:42 AM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Maybe I missed it somewhere, but are you just going to be running those ITBs open to the world? Don't tell me the engine bay will protect them
I've seen some cage-reinforced foam filters that tend to work really well on ITBs being on other forums.
Making a custom intake shroud for them seems optimal, but I doubt you could make one that wouldn't affect the VE and change your numbers/curve.
Old Mar 7, 2010 | 02:49 PM
Kgkeen101's Avatar
Old Mar 16, 2010 | 08:29 AM
jkpgt96's Avatar
What are you spinning the motor to?
Old Mar 16, 2010 | 09:50 AM
Kgkeen101's Avatar
Old Mar 18, 2010 | 07:16 PM
jkpgt96's Avatar
Wow...impressive! I am doing an all out n/a build as well right now, should be done in a month or so, but I am spinning to 10000 rpm. I have to spin that high to try to achieve my power goal of 290whp n/a. I say this because although the motor I am doing is only a 2.5 I find it very impressive that you make that much power n/a only spinning to 8000!
Great work!
Also, have you considered running an electric vacuum pump to try and help reduce windage and help the rings seal even better...?
Old Mar 18, 2010 | 07:27 PM
Great work!
High power does not necessarily mean high rpms... The highest power N/A VQ35s in the world only rev to 7500-8500 depending on displacement.
Old Mar 22, 2010 | 10:59 AM
jkpgt96's Avatar
I realize this..granted the VQ is a much more potent motor to build, and doesn't rev like a KL...In my case is does mean high-rpm, because the motor has a very short stroke and likes to rev.
So..comparing the two I suppose is not fair, but I am still amazed at the n/a power at such a modest rpm.
Old Mar 23, 2010 | 01:28 PM
krazy6's Avatar
You are building a KL? Those motors are badass! Rod/stroke ratio is insane.
Im sure you have seen this guys. I would copy his build lol.
http://www.youtube.com/watch?v=Nbu0QtUKcZM
Best sounding V6 ever!
Old Mar 26, 2010 | 01:28 PM
jkpgt96's Avatar
Haha...yeah. I know leo, he is a good guy. He has helped me some with getting the oiling system setup on my car, and I have been helping him with questions to get his motor converted over to solid lifter and such.
He about a month and a half ago went 11.20 @ 120...on stock heads and hydraulic lifters/cams. He should be clear of 300 when it goes back together. My build is very similar to his old setup, except I am running 250 duration @ .050 and .385 lift (a little more lift and duration) and I am already solid lifter. I am also running a vacuum pump, custom longtubes, and completely worked over heads. I am shooting for 300 n/a, he is going to be over 300 n/a..but mine is a street car his is not.
I'll post pics in a couple months when I fire it up. PM me if you would like to know more.
Back to topic..sorry.
Old Mar 26, 2010 | 08:23 PM
krazy6's Avatar
You have a PM!
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
6spd4dsc
Mar 4, 2016 05:19 PM
homewrecker
Sep 24, 2015 07:01 PM
