Dynoed the Max but terrible numbers
Hey guys, I finally dynoed the max and got it tuned. However, the numbers are terrible and I don't know the reasons why. The guy who tuned my car was confused as to why my numbers were low as well. Help me guys......I don't know why I'm getting this bad of a number. I tuned with a VAFCII.
Forgot to mention that this is a 2nd gear runs so maybe that is why my numbers are low?
Highest HP/TQ was : 217HP/186TQ
My mods are:
HS Headers
Test Pipe
3" cattman
SSIM
LRMAF
Manifold Spacers
My mods are:
HS Headers
Test Pipe
3" cattman
SSIM
LRMAF
Manifold Spacers
Nevermind about the kind of dyno, saw it was a dynojet, stupid phone. It look like the stock rev-limiter or SSIM, whichever way you want to look at it, is killing you bc the curve is still climbing at 6.5k.
Your torque is about 50lbs off. I'd question the dyno's load settings. Do you have an exhaust leak anywhere? I just don't understand why your torque would drop off so drastically like that from 5K to 5.5K.
DAMN that is crazy but im no expert on a Dyno you got to wait for Nmex or one of those guys.....but do you be burning any oil and did you do it with the 19s on your car or some different wheels...and if you know the weight of the wheels and tire....but me no expert....
Looks like a 3rd gear run. Law, do you have the runfiles, if not, try and get them, they would be useful.
What's interesting/cool about the curve is that the hp peaks at 6.5k.
What gear was this? 2nd gear will give very low torque readings, and well, as we all know the equation, will result in lower hp numbers also.
AFR also looks a bit thick.
Doesn't matter the temp or RH, that's what the correction factor is for. (CF).
This is a dynojet, so no load settings.
No, I don't have the runfiles. I can try to get them but they are like maybe a few months back. I might just try with a new dyno run again but this time with 3rd gear as long as I know how to do a dyno run in 3rd gear.
Wheels shouldn't have much to do with it.
Yeah, take it to about 70 MPH and then stab it.
Any SES codes? And lean it out a bit.
Ge the runfiles too.
After looking at it a bit, it is a 3rd gear run. No way can the operator stab it @ 3000 and it not downshift.
This was a 2nd gear run, I think. But I will have a 3rd gear dyno run but this time I know what to tell them, haha!
For sure get the runfiles. have them email them to you now!
Anyway, here's a comparison of my 2nd & 3rd gear runs.
Same day, same AFR.
BTW,
http://forums.maxima.org/4996439-post4.html
Same day, same AFR.
BTW,
If it wasn't summer, I'd have this all calculated for ya'
i agree with the dynojet being the industry standard, but the dyno dynamics is the heartbreaker..i know
I ran mine on a mustang dyno a week ago and im taking it to a dynojet wednesday just to see if there is a hp difference or not and how much.And because i didn't really get any usefull info from the mustang dyno like good runfiles.All i got was max hp/tq at what rpm and a cheesy little graph you could barely read.I want the runfiles to see if theres any sack i can squeeze out of it with a tune.
lol...i dont know where you are getting this info from but you are 100% wrong. like i said earliers, the dyno dynamics is the heart breaking dyno...
http://forums.evolutionm.net/vendor-...s-dynojet.html
Dyno Dynamics/Mustang Anything load based depend on how they're set up. They can be set up to read anything pretty much.
A 6th gen went on a Mustang and hit 260, got on a DJ and hit 234. And of course, we've seen it break hearts where someone got 230 on a DJ, and got 190 on a load based.
DD's/Mustang Dynos are load based and need to be set up correctly in order to read correctly, and either way, they are apples to oranges.
IMO, load based dynos are best for correct tuning since they apply load according to speed, whereas a DJ just calculates the time it takes to accelerate a drum.
But this is why load based dynos need to be set up properly and parameters need to be taken into account (coefficient of drag, weight, most namely.) Cd has a lot to do with the front end of the car, aerodynamics, surface area, etc.
So I started typing this long reply and realized Im basically saying the samething Nmexmax is saying above me. I just want to add that load based=better for tuning and Dynojet = better for comparing.
James92SE
142
Jan 2, 2024 09:23 AM
Kingofmaximas24
Nov 12, 2015 04:40 PM
ik95
Sep 16, 2015 08:11 PM
