Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
2002 SE Auto 225whp/237wtq WTF
Old Oct 28, 2011 | 09:26 PM
KiNgJaMEs's Avatar
Went to the Dyno Today and was quite disappointed
225 whp and 237 wtq
1) Is it common for the tq to be higher then the HP
2) What had gone wrong I feel that I should be higher
Best track time with I/H/bs Exhaust, Spacers, BOP was 14.1 @ 99mph
NOW
Current Mods:
NWP Spacers
NWP BOP
NWP Torque link
Solid filled rear mount
Stillen Pop Charger/Velocity stack
OBX-R equal length Headers
Cattman 2.5" w Magnaflow Resonator
Magnaflow high-Flow cat
Utec - Street tuned by Sparks03
Track Edition Rays 18" wheels
Shift Kit
Tranny Cooler
Grounding kit
Unorthodox UDP
Red Top battery
Old Oct 28, 2011 | 10:40 PM
NmexMAX's Avatar
dot dot dot ...
A bit rich for my blood my brother.
Do you have the DRF's? Call the dyno place, and have them email you the actual files. But yes, you are rich, too rich.
Tell John to remove some fuel and add some timing. BBMAF?
When I first dynoed, my tq was higher than my tq, currently, that's not the case.
IMO, get a 3" exhaust, a full SSIM, add some timing, (30-33 degrees post 6000), lean some fuel, and of course 3.5" intake/MAF and LW wheels.
3rd gear? I'm assuming? I see the strange jitery data from the tq convertor on that one.
Old Oct 28, 2011 | 10:48 PM
KiNgJaMEs's Avatar
nice thanks for that input your the guy i was wanting to post something.
You hear that SPARKS we have to go back into surgery soon "Mad scientist"
Old Oct 29, 2011 | 12:06 AM
Rods03Max619's Avatar
Nice Mod List, and hope you get all the power out of them, since it looks a bit off....I hope I still can hit the Dyno soon...
Old Oct 29, 2011 | 06:09 AM
essential1's Avatar
My axles cry for mercy...
I like that there is no dip at 5200 rpm and the power doesn't drop off as drastically in the upper rpm range. And you don't have a SSIM or aftermarket cams. That's what i would be happy with.
Old Oct 29, 2011 | 06:15 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
he hit the nail on the head. leaning it out and plussing timing added a 15hp jump in my midrange. think youll see alot more with what hes listed for you *BBMAF, 3inch,SSIM*
Ive never run mine with lightweight wheels plan is to do that once complete to get a good bump on numbers. but those three should have you screaming.
Old Oct 29, 2011 | 07:26 AM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
When I initially did his tune, I had it running at 13.5 until 4000 or so, then dipped to 12.8-12.9 by redline. Did I ever mention that UTEC tunes don't last very long before you have to retune? Yeah... Aaron could attest to this, it annoys him slightly. Timing wise, his is setup with the same tables as mine (mid/high 20s through midrange, 30ish up top).
I doubt he'll get anything much lighter than the track edition wheels unless he wants to go to 16/17" wheels, and I can promise you that isn't happening. My 286whp dynos were on the same wheels... lol
Originally Posted by Cant_Get_Ryte
*BBMAF, 3inch,SSIM*
I've advised James to do such a couple of times, I think. I even know where he can get a cattman 3" for a good deal locally. The same dude might even consider SSIMing another intake manifold...
In terms of torque peak surpassing HP in this case, I think that is normal for a non SSIM automatic. SSIM will drop your torque peak by 6-10 or so and raise the HP peak by a few with most of the gains being under the curve up top.
Old Oct 29, 2011 | 03:36 PM
NmexMAX's Avatar
dot dot dot ...
Tossing my cat and removing the Helmholtz netted me +10whp but only like 1-3 ft lbs too. All that that means is that it added hp to the right of the curve/higher RPM.
Old Oct 29, 2011 | 05:55 PM
KiNgJaMEs's Avatar
I'm back to the drawing board look for number in January or late December if weather permits.
Old Oct 31, 2011 | 12:05 PM
KiNgJaMEs's Avatar
Coming very soon
3" exhaust
BBM Maf
Better tune
full SSIM
Old Nov 2, 2011 | 07:59 PM
Chocolate_Boi_1Der
Originally Posted by KiNgJaMEs
Coming very soon
3" exhaust
BBM Maf
Better tune
full SSIM
gonna be on point if you do. if you check out knightz, he can knock you out a 3.5 intake and from there just have the block welded on.
that was noted. part of the reason i never did a test pipe lol. figure with the slew of new parts im looking at that can be my little bit to push me over my goal if need be lol.
Originally Posted by sparks03max
When I initially did his tune, I had it running at 13.5 until 4000 or so, then dipped to 12.8-12.9 by redline. Did I ever mention that UTEC tunes don't last very long before you have to retune? Yeah... Aaron could attest to this, it annoys him slightly. Timing wise, his is setup with the same tables as mine (mid/high 20s through midrange, 30ish up top).I havent had an issue with the tune we loaded on slot one until yesterday. I noticed it was idling a little richer as it normally sits from 14.9~15.1. Was tagging into 13s so went ahead and switched to map 2. Issue was gone. Drove around on map 1 today and its back to normal...
LOL im on those damn 19s. figure that swapping should free up a good amount just for a good bump on track and or dyno day
I've advised James to do such a couple of times, I think. I even know where he can get a cattman 3" for a good deal locally. The same dude might even consider SSIMing another intake manifold...if its who i think, that guy doesnt answer pm's at all.. I had a huge issue with mine when running with just the nwp block plate. i really hated running the ssim untuned. so much so that i went back to the stock mani with BOP until it got tuned. If you look at teh graph with the ssim prior to tuning and the final graph you can see that it was a huge gain once tuned. think thatll be a good mod for him long as its tuned
yeah. i know manny was sick of me arguing about that damn manifold while i was gone, but the ssim will compliment that 3 inch nicely.
Old Nov 3, 2011 | 11:54 AM
Yes that was my initial problem with a SSIM as well. I did one while untuned and sold it before I got the UTEC. I did have the SSIM when I was spraying that 75 shot, though... Worked well.
Old Nov 3, 2011 | 06:09 PM
Chocolate_Boi_1Der
lol would like to stay away from the spray, but im sure that would be a helluva ride
Old Nov 20, 2011 | 12:46 PM
A Kingjames when you went to the track were you shifting the Auto or just had it in drive...
Old Nov 20, 2011 | 06:13 PM
KiNgJaMEs's Avatar
It was in 3rd, no shifting
Old Dec 28, 2011 | 05:42 PM
Grand_hustle17's Avatar
i dynoed 238whp 231TQ
with just
Self made Intake
OBX Unequal length Headers
2.5" Crush bend Catback
Some thing aint right here or it must be on one em low reading dyno's...... id like to know who is selling this 3" Catback though
Old Dec 30, 2011 | 03:23 PM
KiNgJaMEs's Avatar
Update: 3" Cattman installed today
Old Jan 4, 2012 | 11:51 AM
NmexMAX's Avatar
dot dot dot ...
Did you ever get the runfiles? That looks like Antarctica for area under the curve, that's a thick torque curve and as essential pointed out, not much dropping off.
Old Jan 4, 2012 | 12:00 PM
KiNgJaMEs's Avatar
I think I have them I'll got through my thumb drive and email them to you if you want, I'm not a DYNO genius by any means.
Old Jan 4, 2012 | 03:47 PM
oooh he's got more than this
Old Jan 4, 2012 | 08:54 PM
ranmas2004's Avatar
Did I ever mention that UTEC tunes don't last very long before you have to retune? Yeah... Aaron could attest to this, it annoys him slightly. .
I read about another persons experience on here with the UTEC not holding the tune. I thought they just had a bad UTEC.
Old Jan 4, 2012 | 11:43 PM
BrooklynRussian's Avatar
Damn I had 234whp and 246tq with Gutted Pre-cats / Warpspeed y-pipe + test pipe / Tsudo 2.5inch mid-pipe / Megan M-DT muffler / Berk intake with Apexi Filter / BOP plate / 2* timing advance and no tune
Old Jan 5, 2012 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
Nice torque #.
Dynojet?
The area under KingJames curve, it's impressive.
He breaks 200 at about 4300 RPM, when I made 257 peak, I broke 200 fwhp @ 4300, so there's a lot more than peak #'s here.
EDIT/sidenote
UTEC is pre-ECU, IIRC, if so, then that means one can record paramters (i.e. timing) before and after, and waay after a UTEC tune and see is up, and if it is indeed changing or going back to what it was before, (via say Cipher). Same goes with the AFR, which can be done via a WB.
Old Jan 5, 2012 | 11:13 AM
Yep it was on a dynojet
Old Jan 5, 2012 | 12:38 PM
NmexMAX's Avatar
dot dot dot ...
Very nice!
Do you have the SAE corrected numbers?
Those numbers might be slightly inflated due to the slightly higher than SAE value atmospheric pressure, and the cooler temperature than SAE.
Old Jan 5, 2012 | 02:06 PM
Very nice!
Nope, no corrected numbers so yea the numbers are +/- a few, but the elevation isn't that high and the temps ranged from 50-60
Old Jan 6, 2012 | 03:38 AM
Nice torque #.
Dynojet?
EDIT/sidenote
Hopefully when they tune they bumped timing as with the UTEC that's where the biggest gains are... not just adding or dumping fuel....
Old Jan 6, 2012 | 06:40 AM
KiNgJaMEs's Avatar
Well right now I know there is NO timing being advanced anywhere, all we did was added and dumping fuel.
Old Jan 6, 2012 | 10:30 AM
NmexMAX's Avatar
dot dot dot ...
Room for improvement then.
Can't wait to start my UTEC adventure.
Old Jan 6, 2012 | 07:47 PM
Well just so you know, "can't get ryte" had similar numbers before adjusting timing..... just so you know, he came out with 263whp after messing with timing
Old Jan 6, 2012 | 08:38 PM
KiNgJaMEs's Avatar
NICE I need to get a Utec GURU "Sparks03" cough cough, You listening to help me out
Old Jan 7, 2012 | 07:46 AM
Need a lil more dyno seat time to adjust n bump timing I believe..... "some rival".... 10yrs later ur stilltrying to figure out how to be faster than me
Old Jan 7, 2012 | 10:17 AM
KiNgJaMEs's Avatar
Look at GrandHustler, still thinking someone is competing with him. I'm just getting my whip breathing right and it has YOU worried.
Old Jan 7, 2012 | 04:10 PM
who me???.............. never that... i been gave up that comp waay before ur car had a chance at breaking 13's lol... far as i know im helping you achieve what ive been doing years ago
Old Jan 9, 2012 | 07:47 AM
NmexMAX's Avatar
dot dot dot ...
cant get rytes was on a different type of dyno though.
I say go full SSIM (PM me, I got one FS), and of course all the associated stuff with it (BBMAF, 3" or greater intake, and 3" exhaust, etc).
You should be making a lot more hp @ 6000+.
Old Jan 10, 2012 | 02:26 PM
you miss the overall point... screw just numbers... i was trying to explain that cant get ryte gained significantly with messing with timing... not just comparing numbers, numbers can differ, gains by tune can and most likely will be similar no matter the dyno
Old Jan 10, 2012 | 02:33 PM
NmexMAX's Avatar
dot dot dot ...
Do you know how much he gained? I can't wait to start palying with my UTEC.
Only problem is, I'm sure my timing is already slightly advanced with the TS ECU and the SAFCII corrections ... So my threshold might be lower. Although now with the 82mm MAF and associated 3.5" intake, I'm actually adding about 12-14% fuel via SAFC.
I also recall both Aaron and Jime seeing no difference when advancing past a certain point (somewhere in the 30º -31º range). Pretty sure Jime went as high as 33º.
I'm planning on using the Cipher to get a "baseline" timing map, and adjusting from there.
Old Jan 10, 2012 | 07:13 PM
about 40whp... higly doubt you will gain that much though
Old Jan 10, 2012 | 07:58 PM
tookrzy4u192's Avatar
here's one for sale.. 300 shipped
http://my350z.com/forum/turbos-nitro...o-xs-utec.html
Old Jan 11, 2012 | 06:52 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by tookrzy4u192
He already has one.
NOW
Current Mods:
NWP Spacers
NWP BOP
NWP Torque link
Utec - Street tuned by Sparks03Track Edition Rays 18" wheels
Shift Kit
Tranny Cooler
Grounding kit
Unorthodox UDP
Red Top battery
