Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
15k oil change
Old Jun 10, 2003 | 06:16 PM
slickrick's Avatar
15k oil change
i will be needing an oil change and i was wondering if it is worth it to put in mobil1 or stick with the generic brands places give? and i live in south florida so should i stick with 10w-30 or go with 5w-30?
Old Jun 10, 2003 | 06:29 PM
skandalouz's Avatar
10w-30 in the summertime... 5w-30 will do when it's not so hot out.........
Old Jun 10, 2003 | 06:32 PM
PCGuRu2K's Avatar
I thought it was the other way around. Since 5w-30 is thinner then 10w-30?
Old Jun 10, 2003 | 06:40 PM
limsandy's Avatar
Our stock motor oil uses 5W-30. In the summertime, you can use 10W-30, but not in the winter. I'd say just stick with the 5W-30 for consistency. As far as brand goes, Amsoil synthetic oil is probably the best for our car. Mobil1 is not bad either. Or you can use Pennzoil like dealers.
~limsandy
Old Jun 10, 2003 | 07:44 PM
iwannabmw's Avatar
With a synthetic, 5W-30 or 10W-30 is fine year round.
Old Jun 11, 2003 | 10:21 PM
slickrick's Avatar
i use my car alot would 5w-30 be better than 10w-30? i have 10w-30 in there now.
Old Jun 11, 2003 | 10:37 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
PLEASE do a search. I think it's working now.
There are MORE than enough threads on this.
Old Jun 12, 2003 | 06:58 AM
iwannabmw's Avatar
If you drive a lot of miles, the oil that will give you the longest service life without shearing would be the Mobil 1 10W-30 (unless you're interested in Amsoil).
Old Jun 12, 2003 | 12:08 PM
slickrick's Avatar
ice- i would but ive made a thread about this awhile ago and never got a definitive answer. looks like ill try out some mobil 1 10w-30.
Old Jun 12, 2003 | 12:39 PM
IceY2K1's Avatar
Personally, I'd go with a 10W-40 synthetic for superior protection in FL hot climate, however the Mobil 10W-30 is a good choice.
Only oil analysis will tell you what's best for YOU though.
Old Jun 12, 2003 | 12:42 PM
slickrick's Avatar
you think so? im no oil pro thats why i sound like a newbie here. but if i go to an oil change place and ask for 10w-40 they will either say no we dont have it or wanna charge me more. is this correct?
Old Jun 12, 2003 | 12:59 PM
IceY2K1's Avatar
Probably. I ASSumed you were going synthetic, so I spouted off a 10W-40. I don't think dino(regular) oil comes in that and I wouldn't use if it did, ONLY synthetic.
If you MUST get your oil changed at a lube shop just stick with 10W-30 and get it changed regularly. I personally wouldn't go over 4K miles per change until you get an oil analysis.*hint*hint*
What kind of driving do you do? What are the temps like in FL? Are you unable/unwilling to change your own oil?
Old Jun 12, 2003 | 01:08 PM
slickrick's Avatar
where can i get an oil analysis done and how much will it cost? i will never change my own oil, so ill have to stick with lube shops. in fl its between 85-98 degrees all the time and its hott and humid. i drive fast because i drive a maxima. but i only floor it once a day to keep the ecu in check.
Old Jun 12, 2003 | 01:11 PM
IceY2K1's Avatar
You should be fine with a QUALITY dino oil such as Mobil 10W-30.
For more info on gettin an analysis read this:
http://forums.maxima.org/showthread....hreadid=100060
JoshG
51
Sep 21, 2015 10:41 PM
f.matejaiii
Sep 21, 2015 12:09 PM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
