Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
oil change
Old Jun 11, 2003 | 06:20 AM
xl max03 lx's Avatar
oil change
hey guys was just wondering how often you guys get your oil change done on your maximas b/c I know that in my fathers lexus its every 5k miles or every 6months.
Old Jun 11, 2003 | 06:43 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: oil change
i change mine appoximately every 4000 miles with mobil 1 5w-30 and nissan filter. sometimes ill change it sooner if i know i will be busy or out of town but i try not to let it go by 4500 miles.
Old Jun 11, 2003 | 08:02 AM
NizanDrivn's Avatar
Re: Re: oil change
you might want to browse back a few pages back (last two months), there are a least two post on this topic...
Old Jun 11, 2003 | 08:42 AM
PCGuRu2K's Avatar
I change mines about every 4K with Mobil 1 5w-30 synthetic and Mobil oil filer..
Old Jun 11, 2003 | 08:44 AM
NT2SHBBY
Old Jun 11, 2003 | 10:46 AM
Virus's Avatar
It just depends on the oil and filters you use. If you use Amsoil and a Amsoil or Mobil 1 filter you can probably get 15-20k oil change intervals as long as you change the filter every 7k. Mobil 1 you can probably get 5k. Redline you may be able to squeeze 10k change intervals.
Old Jun 11, 2003 | 11:25 AM
naerok's Avatar
Do you have a get a syn oil filter when using syn oil? or you can use a regular oil filter when using syn oil?
Old Jun 11, 2003 | 12:42 PM
Virus's Avatar
You don't have to, but the oil filter is just as important as the oil itself. In some aspect it's more important. Mobil 1, Amsoil and K&N are the best filters. The STP, Nissan OEM and PureOne are the best regular filters. Do not buy FRAM! SVTPerformance.com has a link to a test done on paper media filters done in the winter time that showed a tremendous amount of paper media oil filters that had cracked. None of the Synthetic fibre media oil filters exhibited this problem.
Old Jun 11, 2003 | 01:03 PM
Virus's Avatar
First, the Mobil 1 filter will perform just fine on startup. It is a function of flow rate and the bypass valve PSI pressure rating. No problem there.
The trouble with paper element filters like the Motorcraft is that they can, esp. in very cold climates or in extended drain use, which some of do because we use the best synoils, the filter media can fracture. We have seen this in taxi durability testing, and in a surprising number of street cars. Once the element fractures, a large % of the oil is unfiltered. When was the last time anyone cut open about 100 filters and checked?
CU did oil tests a few years afo, and found the same thing - a high percentage of fractures in oil filter media.
The media used in Mobil 1, Amsoil and others are synthetic and/or glass fiber based. They are almost completely resistant to fracture, and have higher multi pass and overall filtering capacity.
Other than those reasons, I cannot imagine why anyone would not use the regular filters.
RE: Hastings - I have a concern about their ability maintain adequate flow rates.
RE: Ther Motorcraft oil and filter are "the best" for our cars. Says who - Ford? A degreed tribologist with no axe to grind either way. References count - do you know the credentials of your advisors?
Is the stock exhaust "the best for our cars". Are the stock tires "the best for our cars". Depends on your priorities. For tires, the stock F1's are a good compromise for day to day driving, wet weather, etc. For all out drag or track performance, they are not.
Same thing with oil/filter. The Moto stuff is fine, but some of us want higher performance.
Old Jun 11, 2003 | 05:36 PM
VQ35DE's Avatar
HELP
VIRUS,
I went to the site but can not find the link to filter info, can you help. THANKS
Old Jun 11, 2003 | 06:19 PM
Virus's Avatar
This is all that I could find.
Old Jun 11, 2003 | 07:07 PM
VQ35DE's Avatar
But how do you get to the data after you go to that site.
THANKS
Old Jun 11, 2003 | 09:31 PM
Virus's Avatar
THANKS
You have to register and then do a search for Amsoil.
Old Jun 12, 2003 | 05:25 AM
VQ35DE's Avatar
THANKS!
Old Jun 12, 2003 | 10:02 AM
aznsap's Avatar
what if i use amsoil synthetic and oem nissan oil filter? can i get by with 15k oil change intervals if i change the filter every 7k miles?
Old Jun 12, 2003 | 10:22 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Possibly, if:
You change the OEM filter every 5k.
You have your oil analyzed after every interval to see how it's doing.
Me personally, I did the one year Amsoil interval for 2 years, with viscosity thickening noticeably at the end of 2 years, which can cause an "acidic" environment for subsequent oil changes and continuing to go 15k and up annually between changes and shorten the usable life of the new oil more than it was when I initially began using Amsoil.
Even though only doing 2 oil changes in that time was pretty nice.
Old Jun 12, 2003 | 01:55 PM
aznsap's Avatar
Originally posted by bill99gxe
Possibly, if:
how many miles did you put on in those periods? so how ever many miles you put in each interval, you think going that many miles is okay before switching the oil, so long as the filter is replaced every 5k?
Old Jun 12, 2003 | 02:28 PM
bill99gxe's Avatar
I think it was 15k the first year and 11k the next.
I can't intelligently answer whether it's ok for you because I don't know your driving conditions and (especially) the current condition of your current oil.
Lab analysis is the best first step and then go from there.
JoshG
51
Sep 21, 2015 10:41 PM
f.matejaiii
Sep 21, 2015 12:09 PM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
