Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Switching back and forth....
Old Jun 21, 2003 | 12:04 PM
leungjc78's Avatar
I first want to say that I don't know dirt about oil..(or cars for that matter)..
But I've been using M1 synthetic since around 8-9000miles..because I was told that they are better...(and why is that may I ask??)
Anyway....I go to Nissan for regular maintance after the change and told them NOT to change the oil...and they did. I change back to M1 1000klicks later. Nothing happened until yesterday, I took the car for maintence and even told to do so...and DING! DING! DING! They drain my 2 week old, more expenisve than regular, M1 tri-synthetic down the drain....!
I was SOOOOO not impressed..
So, the question is...is changing the oil back and forth really bad for the engine?? Cause I don't want to change back to M1 and risking it.
Thank!
Old Jun 23, 2003 | 07:26 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
No, it's not a big issue.
More importantly:
Please use the 15208-9E000 OEM oil filter. DO NOT let Nissan put the 16208-65F00 OEM filter on there. Both are for VQ engines, but the 65F00 filter has Fram-esque cardboard end caps and should be avoided.
Also, if you are under 10k, using dino oil will help the VQ break in better and faster.
Old Jun 27, 2003 | 06:55 AM
jay beede's Avatar
my '03 maxima has an xxx01 filter on it. same as 65F00?
Old Jun 27, 2003 | 08:54 AM
Jatan's Avatar
Why did you go to the Nissan dealer the second time?
Old Jun 27, 2003 | 09:06 AM
bill99gxe's Avatar
It's thought that the 65F01 filter is a better-made filter (i.e. metal endcaps) to facilitate early engine break-in. It is the original filter on all VQ35DE engines from the factory.
Nissan dealers do not sell the 65F01 filter, so we can't cut one open and definitely verify the speculation. They will simply use the 65F00 unless you tell them otherwise.
JRod28
Dec 29, 2023 09:56 PM
Justin Kroll
Sep 2, 2015 11:06 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
BobMax
Aug 15, 2015 12:35 PM
