Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Which grade oil should I use?
Old Jun 23, 2003 | 10:30 AM
GMoney's Avatar
Hello Everyone,
I just broke the 1,000 mile mark on my '03. I know the manual recommends oil change at 3,750, but I guess I have old school thinking and want to change the oil at this time.
I looked through the manual quickly and could not find the oil grade that the motor requires.
Can anybody help me with this?
thanks
Old Jun 23, 2003 | 10:46 AM
jjs's Avatar
jjs
Re: Which grade oil should I use?
thanks
Try the maintenance forum....since this will shortly get moved there anyway.
johnny2kgle's Avatar
5w-30
Old Jun 23, 2003 | 10:49 AM
GMoney's Avatar
Re: Re: Which grade oil should I use?
on me..thanks
Old Jun 23, 2003 | 10:52 AM
jjs's Avatar
jjs
Re: Re: Re: Which grade oil should I use?
on me..thanks
No problem! Actually was news to me a couple weeks ago when I started noticing oil related threads getting moved left and right...
Old Jun 23, 2003 | 12:20 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Re: Re: Re: Which grade oil should I use?
Old Jun 25, 2003 | 07:51 PM
Pinnacle's Avatar
whats the deal with 15W-50? Is this the stuff I want for hard driving? I just put in 10W-30 today.
I live in hot Tampa, FL and drive hard all the time - thanks for any advice.
What do these numbers mean?
Old Jun 25, 2003 | 09:17 PM
IceY2K1's Avatar
It depends on a LOT of factors such as engine part tolerances, temperature, age(mileage), etc...
You don't need a 15W-50. I wouldn't go that thick ESPECIALLY in a dino. If you don't see sub 20-degree F weather, choose either a 10W-30(dino or synthetic) or 10W-40(only synthetic). However, if there is a chance you'll see cold climate or do lots of short trips without the car fully warming up, I'd choose a 5W-30 for better startup protection.
Honestly, a synthetic 5W-30 will handle anything you can throw at it, but a 10W-30 or 10W-40 will give you a little better protection at 100+F temps. under high load areas like the bearings, cylinder walls, cams, yada yada, where shearing occurs.
The differences in engine protection between the 5W-10, 10W-30, and 10W-40 aren't going to make a noticeable difference, but a 15W-50 or 20W-50 will cause less fuel mileage/performance.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
