Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Fuel additives?
Old Jul 2, 2003 | 11:10 AM
ben99sel's Avatar
Fuel additives?
I'm doing a tune up in a few days and I was wondering if I should use some fuel system or fuel injector cleaner while I'm at it. Any suggestions, or would I just be wasting time with it?
Old Jul 2, 2003 | 11:51 AM
johnny2kgle's Avatar
Redline Oil Corp. make a good Total Fuel System Cleaner (available at Pep Boys). I use it 2 twice a year. If you change oil frequently, 3000-4000 miles, that is also a good time to add it.
http://www.redlineoil.com/products.htm
The other is Chevron's Techron product.
Old Jul 2, 2003 | 06:03 PM
teejnut's Avatar
Do you put the whole bottle of the Redline Cleaner in? Or do you use the increments on the side of the bottle?
Old Jul 2, 2003 | 09:24 PM
joew's Avatar
can we clean the fuel injector system? is it diffcult? do we have a write up?
Old Jul 3, 2003 | 07:01 AM
When you start using it, put the whole bottle in the tank. After doing that, you can put in 2-3 oz. at every fillup.
Here a link about Redline fuel system cleaner.
http://theoildrop.server101.com/ubb/...c;f=5;t=000664
Hope this helps.
Old Jul 6, 2003 | 08:35 PM
Jatan's Avatar
I bought the Chevron Techron Fuel System cleaner a week ago and I put it in a nearly empty tank. The bottle said it'll treat up to 12 gallons, so I filled up the tank with 7 gallons (3-4 gallons left in tank from before) so I had about 10 gallons in the tank and the car was POWERFUL with the regular 87 octane gas! It would go like crazy with the push of the gas pedal! It said every 3,000 miles so I didn't put more in, but after I put in some premium Amoco gas (1st fillup 5 days ago) and premium Citgo gas (2nd fillup 2 days ago), the car isn't moving that fast...
I'm going to get the Redline stuff tomorrow when I go buy a case of oil and an oil filter for my oil change. I probably won't be able to put it in until Friday/Saturday since my tank is more than half full right now. I'll see how that performs since it says I can use it at every fillup
Old Jul 6, 2003 | 08:44 PM
Virus's Avatar
BG44k is the absolute best. It's available at just about any car dealership and some high performance shops. It's usually over $20 a can, but it is awesome. Don't forget to clean the throttle body.
Old Jul 9, 2003 | 07:52 PM
Jatan's Avatar
Just put in the RedLine stuff ($4.50 at Pep Boys) and the new premium Shell gas and the car is running great! I need to clean the throttle body soon and change the spark plugs to NGK (I think the dealer put in cheap ones when I bought the car). Also, I just found out that my Low Fuel light works =) It comes on with about 1.5 gallons of fuel left.
Old Jul 16, 2003 | 10:19 AM
Jatan's Avatar
Last week I put in that RedLine stuff and I switched over to Shell gas and my MPG went from 16-17 to 18 I still need to clean my TB and do a tune up so that should improve it a little bit more The tires are 35 PSI all around, but my suspension is bad so that should improve the miles once I fix that.
I'm going to try the BG44k later on. Still need to find who has it the cheapest around here.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
