Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Engine Swap related fluid questions
Old Jul 9, 2003 | 10:03 AM
ejj's Avatar
ejj
Does a new engine going into the car (42k on the engine) need to be "primed" in any way. Do I need to make sure the block is full of coolant before starting it, or will the system fill itself?
I'm planning on treating this as a new engine. I'm going to use cheep dino oil and a cheep filter for like 20 miles, then use more dino and a nissan filter for about 500 before going back to Amsoil. I have no idea about the oil used in the motor until now. However, it came with a Nissan filter, so I assume the owner had Nissan do the maintenance, and therefor got whatever oil the dealer uses (?).
Make sense?
[EDIT]
Just realized I wrote 'dyno oil' and not 'dino oil'. WTF would dyno oil be?
[/EDIT]
Old Jul 9, 2003 | 10:10 AM
Jeff92se's Avatar
I'm needing a caw
Makes perfect sense. Good call on the dino oil. As for the coolant. When the engine is back in, fill up the coolant and make sure to unscrew any bolts that help get rid of air bubbles in the system. Should be in the manual or use the chilton's online
Old Jul 9, 2003 | 10:17 AM
ejj's Avatar
ejj
Are you refering to the drain bolts in the block? Should I fill the intake tube (from the radiator to water pump) with coolant when the engine's put in so the coolant gets to the pump. I would think starting the car with no coolant around the pump may not be good for it...
I'm sure it is. However, I just started thinking of this at work...I'll read up when I get home.
Old Jul 9, 2003 | 11:23 AM
Jeff92se's Avatar
I'm needing a caw
For 3-gen but 4-th should be similar
http://www.cybrrpartspro.com/Chilton...61CH01_44.HTML
Old Jul 9, 2003 | 11:27 AM
ejj's Avatar
ejj
Hm, never heard anyone reference an 'air bleeder port' for 4th gens. I'll have to look into it. Thanks.
If I can't figure it out, I'm sure removing a temperature sensor would provide the same thing.
Old Jul 9, 2003 | 12:21 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Per Daniel B. Martin (searched a couple of years back) there is no air bleeder screw on the VQ engines.
rbuswell
Nov 17, 2016 04:54 AM
Ray229Harris
Sep 16, 2015 08:16 PM
homewrecker
Aug 24, 2015 08:56 PM
scarletsosa
Aug 17, 2015 09:09 PM
