Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
oil change question
Old Aug 24, 2003 | 06:07 PM
96_Infiniti_I30's Avatar
oil change question
i changed my oil last week with mobil 1 synthetic 0 w 30 and i was wondering if you guys think its ok to let it stay in 4 the whole winter.i might put 8-9,000 miles on it.oh i got a oem nissan oil filter too.
Old Aug 25, 2003 | 10:04 PM
Re: oil change question
anyone? opinions? please.
Old Aug 25, 2003 | 10:11 PM
jetblack5spd's Avatar
change your oil every 3 thousand. its a pain but just do it
Old Aug 25, 2003 | 10:32 PM
minsbang's Avatar
yeah,, just do it.. it's worth it.. don't let your max suffer.. you wouldn't like it if you were the max.. =(
Old Aug 26, 2003 | 06:24 AM
twiggy144's Avatar
especially in winter if you live in a sub-freezing temperatures, change the oil every 3k miles. Below 32F temp creates condensation inside the engine when it cools off after stopping. Water corrupts engine oil. Please promise you will change oil every 3000 miles.
Old Aug 26, 2003 | 06:29 AM
Albertt's Avatar
I mix about 25% Mobil 1 into regular dino oil and leave it in for about 4000 miles in the non-freezing months.
Old Aug 26, 2003 | 06:51 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
why?
Old Aug 26, 2003 | 08:28 AM
johnny2kgle's Avatar
I would change the oem oil filter at 4-5K miles or 3-4 months and top the oil. So around Thanksgiving or before it gets too cold, change the filter. Change the oil and 2nd filter in March on a warmer day.
This would be a good used oil analysis (spreadsheet) for an extended drain test on the Mobil 1 0w-30.
Old Aug 26, 2003 | 09:08 AM
Colonel's Avatar
Old Fuddy Duddy
Originally posted by bill99gxe
why?
Give up Bill, there are like a billion threads as to WHY you DONT have to change every 3K...but aparently we are witnessing the second coming of the Jiffy Lube people.
You know, just do it because we said so...not because you can research and learn.
Old Aug 26, 2003 | 11:37 AM
Jeff92se's Avatar
I'm needing a caw
Remember to change your tires when they are only 1/2 worn out also!
Old Aug 26, 2003 | 05:37 PM
Bman's Avatar
Translation to 96_Infiniti_I30: The answer is YES. Change it early spring.
kmitchel
Oct 30, 2016 05:28 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Johnny9595
Sep 3, 2015 05:18 AM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
