Streering Fluid
Streering Fluid
This will the be 1st winter i will own my max and i noticed on cold mornings if i start my car the power streering is very julty, after the car warms up it goes away so i am thinking that my power streering fluid is freezing
should i drain it and put better stuff in? how do i drain it? and what fluid will work best?
the weather has not getten that cold yet i worry on the very cold days i will do damage
Thanks for the help
Thanks for the help
Originally Posted by twiggy144
Originally Posted by apeg
there we go worked perfect... thanx for the help i will do that this weekend
Originally Posted by theMax
To get one better, get a piece of hose, like you use to bleed the brakes, put one end in the PS and suck some through the hose (don't drink of course) and then lower the end into a jar. You get a little more fluid than what you can get from the turkey baster!
I will give it a shot... but the risk of a mouth full of fluid does not set well with me LOL... thanx for the advice
Maxima.org Sponsor and Donating Maxima.org Member
i did hte same thing and almost got ATF in my mouth
Thanks for the help
Thanks for the help
I had clicking whenever I was turning the wheel. Was sure those were the axles, which did have ripped boots, but after changing them, the clicking noise ot the cold starts was still there. Noticed that my steering fluid was a little below level today, and I believe I was driving like this for 2 weeks. I hope I did not damage my power steering with this.
Just now finished replacing new fluid, Coastal Dexron III. Put lots of rags unbeneith and disconnected the bigger hose to drain the whole reservuar. Clean job! Lets see how it goes now.
I bought the valvoline high mileage power steering fluid but it didn't say anything about dexron II on the label. It was the only thing I could find at Walmart so I bought it. I used a turkey baster to remove some of the old fluid. Does anyone know what type of fluid this is?
Check your owner manual to be sure. I think Maxima uses Dexron III for power steering fluid. Don't put the usual power steering fluid in there. I don't know what those power steering fluids are, but they are not Dexron III.
Originally Posted by JaTaN
Try pushing down and then turning it counter clockwise (like those medicine bottles). On my car, it opens without pushing down
Got it. It's a pop-off, like a medicine bottle.
How much fluid is in the power steering pump? I replaced what was in the reservoir...but how long will that take to "seep" into the system....does it mix in while driving?
I'd like to do this a few more times (every 1k miles since it only takes 3 to 4 ounces) to get most of the dirty fluid out.
I know this is kinda OT
but when the weather's kinda cool in the morning and I turn the steering wheel, I get a wierd whining, and when I'm turning and accelerating the whining goes up with RPM. Is the power steering pump gone or something??
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
Now that the new ATF is going into the system, the steering wheel jerking I had in the cold is gone
