Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Redline MT90
Old Nov 30, 2003 | 01:42 PM
nhall's Avatar
Redline MT90
Just filled up my 2000 SE 5-spd with almost 5 quarts of redline MT-90 tranny fluid. Love it in the cooler weather but when crusiing in 4th gear...it often pops out of gear...3rd does the same, just not as often. No problems with 1, 2 or 5. Anyone else have this experience or know what might be causing it?
Old Nov 30, 2003 | 01:43 PM
Ammi's Avatar
350 Detroit Muscle
do you have short shifter installed?
nhall's Avatar
Nope...stock
Old Nov 30, 2003 | 01:46 PM
spirilis's Avatar
Never had it pop out of gear on me...
It has popped out of gear with my hand resting on the shifter
Old Nov 30, 2003 | 02:04 PM
Ammi's Avatar
350 Detroit Muscle
when you shift, make sure the gears are in all the way before you let go of the clutch. Sometimes, when I shift, it feels like it's in but it's not and pops out. Sometimes, it takes two clicks for my gears to go in place.
Old Nov 30, 2003 | 04:04 PM
iwannabmw's Avatar
I'd put money on the fact you used the wrong location to drain the transmission. It's actually very easy to do, ask me how I figured it out the first time! The correct location is a 12mm bolt located right next to the crossmember. The wrench would have been completely perpendicular to the ground if you used this one.
My thought is you drained the transmission from the hole that holds that 3rd and 4th gear detent ball. There's a small ball and spring that pops into a notch on the shaft when 3rd or 4th gear is engaged. This is part of why you feel the "snick" as you slide into those gears. When you opened the bolt hole, the ball probably fell out as the gear oil drained. If you look in your drain pan, you'll probably find them. Just pop them back in and you'll be good to go.
Old Nov 30, 2003 | 05:35 PM
nhall's Avatar
You nailed it... now i just have to find that stupid ball in the b ottom of a 5 gallon pail of oil! I saw the spring come out but never saw the ball...when reassembling...ball goes in first...then spring...then hex bolt??? or spring, ball, bolt? Thanks a ton!
Old Dec 3, 2003 | 02:23 PM
iwannabmw's Avatar
Oops, been away for a few days, just saw your post. I imagine you already put it back together, but for others the order is ball, spring and then the bolt.
Old Dec 13, 2003 | 03:24 PM
nhall's Avatar
Put new ball in today...now I cant shift into 3rd or fourth so i guess I have 2 ***** in there now....tomorrows task is to remove one...oh boy...any other ideas?
Old Dec 13, 2003 | 04:10 PM
iwannabmw's Avatar
Now that one I have no clue on.
user 11122324
42
Jul 18, 2022 03:35 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
3rdmaxse0
Aug 18, 2015 08:25 AM
RosenKen
20
Dec 21, 2002 10:38 PM
