Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Oil filters
Old Dec 7, 2003 | 07:37 AM
lyonsd's Avatar
Oil filters
Unfortunately the search function on this site is still disabled. And I don't have an owners manual.
I prefer Mobil 1, AC Delco and Purolator oil filters. What are the part numbers of each that can be used in a 2003 Maxima? Additionally, are there larger (longer) filters available in each brand that can also be used?
Finally, what is the oil capacity for the engine?
Thanks.
Old Dec 7, 2003 | 08:03 AM
NYC TAR's Avatar
PL-14459 & PL-24458 & PL-14620 and PL-14622 all fit the VQ35DE. I have a PL-24458 (largest) on my car now.
Report this post to a moderator
Quoted by Bill Oil Master Guru
VQ Oil Filter Part Numbers
VQ30DE and VQ35DE models (OEM uses M20 x 1.5 thread type and 14 psi bypass valve):
Oversized:
Optimum filtration at 20 microns
STP: S6941 ($6.99) 17-22 psi bypass valve
Purolator PureONE: PL24458 ($5.99) 8-10 psi bypass valve
Amsoil: SDF-36 ($9+) 7-9 psid bypass valve
OEM sized:
Optimum filtration at 20 to 25 microns
Nissan OEM: 15208-9EOOO or 15208 -00001 (newer number) (approx. $4 - $6 at dealer) 14 psi bypass valve
Nissan OEM: 15208-00006 (new on late 2k1 to 2k3 Maximas) 14 psi bypass valve
Amsoil: SDF-20 ($10+) 20 psi bypass valve
Optimum filtration at 15 microns
Bosch: 3323 ($5.49)
Optimum filtration at 10 microns
Mobil 1: M1-110 ($12)
Purolator PureONE: PL-14620 ($5.99)
Thimble-sized:
Supertech: ST6607 ($1.97); available at Wal-Mart only
STP: S6607 ($2.99)
Amsoil: SDF-13 ($12+) 12-16 psi bypass valve
Mobil 1: M1-108 ($12)
Purolator PureONE: PL-14622 ($5.99)
Mobil 1 M1-110,108,106,104 and the top valve M1-105 fit the 3.0 and the 3.5 which I have.
hope this help will much btw 4 qt is more than enough
my03maxima
Jul 28, 2024 07:40 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
Justin Kroll
Oct 1, 2015 07:03 PM
