Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
View Poll Results: What should I do next?
Brake Fluid Change
0%
Transmission Fluid Change
50.00%
Radiator Fluid Change
50.00%
Voters: 2. You may not vote on this poll
Maintenance Questions
Old Dec 9, 2003 | 02:14 PM
DaBombX's Avatar
Okay. I love driving a car, but I'm not too good with maintaining a car.
I have a 1996 Nissan Maxima GXE Auto with 143k
I bought is used at 120K last year. The previous onwer had bad record logs.
So i think I pretty much need to do everything.
But what is there to do?
I've had a fuel injector cleaning done about a year ago.
Same with the fuel filter and air filter.
What else is there?
Some that I can think of are...
brake fluid change
transmission fluid change
radiator fluid change
Anything else?
Old Dec 9, 2003 | 07:09 PM
Jatan's Avatar
Change your coolant http://www.motorvate.ca/mvp.php/502 but I don't think you should change the tranny fluid. Your tranny might start to slip or something You can bleed your brakes if you want to... Go change your power steering fluid http://www.motorvate.ca/mvp.php/702 and clean your TB
Old Dec 14, 2003 | 01:06 AM
Dave Holmes's Avatar
All of the above. But if on an extreme budget, I'd do coolant first (it's winter now, you don't want a frozen block), then tranny (way, way over due), and finally brakes (unless of course they are giving you problems, then do them first). With poor maintenance history, definitely change the PCV valve, as I doubt it's been changed. You should be able to do all the above for about $20-$30 or so in fluids, and an hour or two of your time.
If you really want to splurge, do the fuel filter (~$10), air filter (~$7), and don't forget your oil and oil filter if they're due (~$15 if using dino oil and an OEM filter). Power steering fluid can also be changed (has it ever been?). Add about an hour if doing all of those, too.
You could also throw in a bottle of $10 Techron (not Pro-Guard, which is the diluted version for $2.50), if you've used questionable quality gas, but that is personal preference.
Finally, make it a New Year's resolution to stay on top of your car's maintenance needs and you'll be set.
Dave
Old Dec 14, 2003 | 06:45 AM
iwannabmw's Avatar
You might want to consider the spark plugs as well.
Old Dec 14, 2003 | 07:03 AM
Jatan's Avatar
Pep Boys has the 12 oz Chevron Techron Fuel System Cleaner for $4.88 (price cut) and get the one that has the $2 rebate on it so it'll only be about $3 after rebate
Old Dec 14, 2003 | 08:35 AM
2002 Maxima SE's Avatar
PCV, Hoses, Belts, and (check for cracks on CV joints) along with everything else mentioned.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
