Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
How much oil to fill?
Old Dec 29, 2003 | 12:10 AM
99ESMAX's Avatar
I am going to use the Amsoil SDF-20 oil filter. It is larger then the OEM size filter. How much more oil should I be adding into the crankcase since I am going to the larger filter? Thanks in advance.
Old Dec 29, 2003 | 10:47 AM
johnny2kgle's Avatar
Start with the 4.25 quarts. Run it for awhile and check it a few times.
My bet is 1/4 quart.
Metric would be 4 litres to start and 200 to 225 ml to topoff.
Old Jan 9, 2004 | 09:04 PM
Ammi's Avatar
350 Detroit Muscle
Just check your oil and make sure your oil is to the maximum level.
Old Jan 16, 2004 | 12:12 PM
MaximaSE96's Avatar
Maxima Owner
i believe the owners manual calls for like 4 and 3/8 qts.....but 4.5 is fine
Old Jan 20, 2004 | 09:34 AM
99ESMAX's Avatar
As you know...
Used the SDF-20 Amsoil oil filter and had to use 4.5 litres of Amsoil ASL 5W30 oil. As you know the dipstick is useless. How can one get an accurate reading? I used 4.25 litres before with OEM sized filter. So far so good with this oil and filter.
Old Feb 2, 2004 | 01:14 AM
Noslen's Avatar
right!!! how the hell do u read that thing accurately?
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
ef9
Oct 4, 2015 08:43 AM
