Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Flush and fill with Amsoil synthetic in auto tranny results.
Old Jan 21, 2004 | 05:57 AM
Rafe's Avatar
Last Friday got the dealer flush and fill with Amsoil in the tranny for 119.00. Well there is a noticable diffrence in acceleration , not supercharger or turbo acceleration , but it definitely is a tad bit quicker on take offs. Shifts are smoother,and highway kick downs are more instant. Especially when traveling at speeds of 75 then mashing the gas, the car flys to a 100 alot quicker.
MPG went up from 26.7-27.2 on the highway, 24.8 -25.1 city. I fail to mention i also have amsoil in my engine.Was it worth the price? I think so......
Old Jan 21, 2004 | 06:31 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Amsoil ATF is excellent. I've been very pleased with my initial used ATF results on both my vehicles.
Old Jan 21, 2004 | 06:54 AM
Rafe's Avatar
You too, good deal , i wish i used it on 94'Z Twin turbo when i still had it. I think its a good upgrade. Once i change my spark plugs then upgrade my rotors too crossed drilled rotors (right is starting to warp), then i will start modding my engine. I told the guy at the dealership to check all the codes and TSB. They said my car is running flawless.
I think a good running car w/mods is better than not so good running car w/mods.
49,9XX and happy!
Old Jan 21, 2004 | 07:11 AM
NCTRNL's Avatar
Did you have to bring the Amsoil in and have them use it or did they have it at the dealership?
Old Jan 21, 2004 | 07:21 AM
bill99gxe's Avatar
A lot of places won't substitute "external" ATF for service, even if you pay for their standard charge which would use their fluid.
Old Jan 21, 2004 | 09:07 AM
Rafe's Avatar
Nope , the dealership had it, i could have brought the oil from an outside vendor , but it would have been more. $92 for the ATF from an outside vendor plus $70 from dealership on service. Basically i paid $50 bucks for the Amsoil if you had to break it down form the 120 that i spent. I was sold.
11.5 quarts had to be put in after the flush.
Old Jan 21, 2004 | 11:36 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Is mixing with regular ATF or switching on a HIGH mileage vehicle any concern?
If not, then how long should I run for the first change to synthetic?
Old Jan 22, 2004 | 01:31 PM
Rafe's Avatar
From what the service manager told me , you don't want to mix the two, either you stick with regular ATF or go Synthetic.
It really doesn't matter wether your car has low or high , if you switch , most new high end cars come with Synthetic already in there engines/tranny.
Old Jan 22, 2004 | 02:27 PM
iwannabmw's Avatar
No real issues with switching a higher mileage tranny to synthetic as long as it's had regular fluid changes. If it's been neglected at all, some problems MAY crop up.
Old Jan 23, 2004 | 04:03 PM
IceY2K1's Avatar
What kind of problems? Why?
It's been pretty well maintained, but it's starting to clunk every now and then on a hard upshift and coming to a stop.
Old Jan 26, 2004 | 07:32 PM
iwannabmw's Avatar
On a high mileage tranny that has seen lots of use and hasn't been maintained well, the problems can start when the fresh fluid cleans out any deposits left behind on some of the components (mostly friciton material on the clutch packs). In some cases, it was these deposits that kept the tranny operational. This is the same reasoning behind people not believing you should change the fluid at all at a certain point or you risk slippage/failure. I think in both cases the dangers are hyped way too much and the probabilty of a problem is remote, but there is the potential. It's a similar argument to switching high mileage engines over. Some people swear up and down the engine WILL leak when you switch. In practice, most of them don't, but it is a possibility depending on how well cared for they were.
Old Jan 26, 2004 | 11:24 PM
IceY2K1's Avatar
Got ya...thanks.
Old Jan 27, 2004 | 06:24 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Dealership as in Nissan Dealership? I'm pleasantly surprised...they must buy it by the drum in order to sell for that price.
Fbana41
Aug 29, 2016 12:18 PM
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
