Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Power Steering Fluid
Old Feb 5, 2004 | 04:32 PM
00MAXI's Avatar
How often do you guys change or flush your fluid?
Old Feb 5, 2004 | 05:11 PM
Jatan's Avatar
You can pay money to have it done professionally or you can do this: http://www.motorvate.ca/mvp.php/702
I chose the 2nd method and replaced the fluid with ATF. I took out some fluid (using the method in the site above) and then I put in ATF. A week later I did the same thing. I did it 3 times so far and I'll do it again when the weather gets better.
My jerky steering when the car is cold is gone now I'll just keep doing this until I finish off the ATF bottle
Old Feb 6, 2004 | 10:48 AM
00MAXI's Avatar
I have a bottle of Mobil 1 synthetic ATF is it ok to mix the two? The turkey baster method doesn't look like it takes all of the old power steering fluid out.
Old Feb 12, 2004 | 10:29 AM
rcy's Avatar
rcy
According to the Mobil website, the synthetic ATF is fully compatible with regular ATF.
lowpost99
Oct 26, 2025 06:53 PM
captchaos
Mar 15, 2016 12:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
