Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
What kind of manual tranny fluid should i get
Old Feb 26, 2004 | 02:44 PM
3rdgenmaxima's Avatar
I have a 94 se and recently i have been having problems in changing gears. At first it just didn't want to go into gear, so i checked the slave cylinder and it was completly dry. So i put som dot 3 brake fluid in it, and it regained pressure and drove normal again. My question is, do you think i might have a possible leak in the line, and what kind of tranny fluid do you recomend for my Maxima.
Old Feb 26, 2004 | 04:34 PM
spirilis's Avatar
I would have a look at the entire clutch hydraulic system!! You don't want to drive it too much with a clutch that doesn't fully disengage... that can tear up the tranny real fast.
Redline MT-90 or Amsoil are the recommended tranny fluids. Redline MT-90 at least is known to improve shift quality by making the synchros work easier.
Old Feb 26, 2004 | 04:48 PM
I really have no choice but to drive it, this is my only car. I am going to have it looked at, but I was also looking into other alternatives in tranny flued. I will go for the Redline Mt-90 where can I get this at.
pktaske
May 6, 2016 07:49 AM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
