Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Squeaky Brakes
Old Mar 27, 2004 | 01:38 PM
felixdacat's Avatar
Squeaky Brakes
Hey everyone, my brakes are squeaking every now and then... Is there a lubricant or some sort of spray to spray on the rotors or brakes to stop the squeaking?
thanks in advance.
Old Apr 3, 2004 | 09:58 PM
Redsand187's Avatar
You don't want you put any lube on your brakes, that will cause you not to stop.
I suggest you clean your brakes more often. The problem you are running into is caused by the brake dust build up.
With metalic pads, the dust contains small metal particals. So when the dust builds up, and you apply the brakes, you have a metal on metal contact, causing the squeel.
If you clean the brake dust off often, you will not have this problem very often. (unless you are a heavy braker, then I suggest some new ceramic pads)
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
