Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
added extra engine oil
Old Apr 11, 2004 | 07:51 PM
trubd's Avatar
I accidentally added extra engine oil.. about 5 quarts total. How bad is that?
Old Apr 11, 2004 | 09:24 PM
Maximum96's Avatar
shouldnt it be 5 quarts of oils anyways??i always put 5 quarts, i think some put 4 1/2 though
Old Apr 11, 2004 | 10:04 PM
Jeff92se's Avatar
I'm needing a caw
1/2 qt is not too bad. You could just drain it out. But way too much is bad. If the oil gets flipped up by the crank, it gets air in the oil. That causes the oil pump to cavitate and your engine loses oil pressure.
Old Apr 12, 2004 | 03:52 AM
VQ35DE's Avatar
Get it out.
Old Apr 12, 2004 | 05:21 AM
2002 Maxima SE's Avatar
Which car do you have? The 2002 takes 4.5 qts (with filter change). An extra 1/2 quart will not hurt anything.
The first time I read this...I thought you added an extra 5 qts...that would be bad.
Old Apr 12, 2004 | 09:25 AM
RaTgoesMaX's Avatar
I would just unscrew the filter and dump out the oil in it and then screw it back on. This will be about a cup or more, then recheck it. I`ve done this and it works.
Old Apr 12, 2004 | 10:10 AM
VQ35DE's Avatar
Yte VQ35DE takes 4.25 quarts with a filter change.
Old Apr 12, 2004 | 04:37 PM
Maximum96's Avatar
so we should put in about 4 quarts of oil???ive been putting 5qts every oil change!
Old Apr 12, 2004 | 06:14 PM
RaTgoesMaX's Avatar
What does the dip stick show?
Old Apr 13, 2004 | 08:02 PM
trubd's Avatar
I cant remove the filter at all even with the filter wrench and my super-strong cousin tightned the plug way out of specs. So i just left the oil in there, hopefully in a couple of days the oil gets burned a little. Ill be watching it carefully but the real question is how much damage will it do?
Old Apr 14, 2004 | 03:44 AM
VQ35DE's Avatar
The real question is that filter and plug WILL have to come out someday, why not now?
Old Apr 14, 2004 | 09:37 AM
RaTgoesMaX's Avatar
Talke a LONG screwdriver and ram it in the filter and then lever it off. It worked for me.........
Old Apr 14, 2004 | 04:38 PM
trubd's Avatar
i just brought that filter for 12 bucks ! I dont want waste my mula so quickly :O(
Old Apr 14, 2004 | 06:17 PM
RaTgoesMaX's Avatar
OK, so it hasn`t been on very long then?
Old Apr 15, 2004 | 04:20 AM
VQ35DE's Avatar
So just drain some out of the drain plug.
Old Apr 15, 2004 | 06:39 AM
RaTgoesMaX's Avatar
LOL, that would be a trick and a half. Once you remove that drain plug try to screw it back in with over four litres trying to escape.
Old Apr 15, 2004 | 07:28 AM
VQ35DE's Avatar
I have done it before and it is easy. I didn't say to take the plug ALL the way out and stick it in your pocket and watch all the oil run out!
Old Apr 15, 2004 | 07:52 AM
matty's Avatar
take the plug out ever soo much till the oil starts to drain...wait alittle bit till you think is good then tighten it back up Dont take it all the way cause youll never get it back on without making a mess
-matt
Old Apr 15, 2004 | 07:33 PM
trubd's Avatar
ill give it a try this weekend, thanks guys
Old Apr 15, 2004 | 07:55 PM
Larrio's Avatar
The Definitive AE Master
oh so true. My friend's mechanic put an extra 1.5 qts into his 3000gt vr-4. We were wondering why the oil pressure gauge keeping going off for low oil pressure everytime the car was in idle or with the clutch in.
also, he just got a SES light for the MAF sensor (oil come back around into the intake tract and stained the sensor)
Old Apr 15, 2004 | 08:57 PM
fishpony's Avatar
i've heard it's better to have a little less oil than too much oil. is this true?
Old Apr 16, 2004 | 05:54 AM
RaTgoesMaX's Avatar
A little less won`t hurt. I check mine in the morning prior to start-up, if it is a touch below the max line I just leave it. I don`t top up if it isn`t at least a half quart.
Old Apr 17, 2004 | 02:10 PM
maxdick's Avatar
lever it off? isn't the filter meant to be screwed on?
Old Apr 17, 2004 | 02:47 PM
RaTgoesMaX's Avatar
Ok, I figured someone may not get my drift,(no problem, I didn`t explain it very well). Put the screwdriver into the filter at a 90 degree angle and then start to turn it counter-clockwise by gripping it with your hands and turning it. (lever effect).
BkGreen97
Apr 2, 2016 05:47 AM
fastcarny
Oct 6, 2015 10:42 AM
kjlouis
Oct 3, 2015 05:29 AM
03VQMAX
Sep 5, 2015 03:47 PM
A32goldylocks
Sep 2, 2015 06:39 AM
