Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
ATF = power steering fluid?
Old Jun 10, 2004 | 08:41 AM
maximus_96's Avatar
i thought i read somewhere that they're the same.
Old Jun 10, 2004 | 08:54 AM
jbreit's Avatar
I doudt they are the same. I would beleive that they are close...as they are both being used in a hydrallic system...but I would never try it. All the different fluids under the hood of your car are tailored to specific needs and generate different sealing requirements and so on. I have heard of powersteering fluid ending up in brake systems and all the seals going bad....just doesn't seem worth any risk.
Old Jun 10, 2004 | 09:31 AM
Kashoggio's Avatar
yes you can use atf in your power steering
Old Jun 10, 2004 | 11:12 AM
2002 Maxima SE's Avatar
Yup, ATF is power steering fluid. I drained mine from the tank and refilled with synthetic M1 ATF.
Old Jun 10, 2004 | 11:57 AM
Ant96GLE's Avatar
On other cars not ours. We use ATF in our hydraulic system, we dont use power steering fluid.
Old Jun 11, 2004 | 05:42 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
The owner's manual for my '98 states you can use Dextron III ATF in the power steering unit...I have used synthetic ATF in it (and in several others) very successfully for the past several years.
With that said, some manufacturer's require special power steering fluids for their systems. For example, Honda specifically warns against using ATF in their power steering systems and they require a special PS fluid (available in the aftermarket) formulated for Honda cars. Some GM cars also require a PS fluid that meets their spec.
So whether you can use ATF or not depends on the manufacturer.
Old Jun 12, 2004 | 02:48 AM
verno-dub's Avatar
Subaru recomended ATF for my powersteering fluid in my WRX.
lowpost99
Oct 26, 2025 06:53 PM
captchaos
Mar 15, 2016 12:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
