Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
AT and radiator flush, DYI or service pro?
Old Jul 5, 2004 | 06:28 PM
NizanDrivn's Avatar
My Max just hit 30k and I was looking to do an AT flush and radiator flush....For the AT flush Nissan charges about $109 and the radiator is about $70...Is it worth having th AT flush done by Nissan techs, or should I take the car to a local mechanic, or DYI? As for the radiator flush, this is DYI is it?
Links to AT and radiator flush are welcome....
Old Jul 5, 2004 | 07:24 PM
GimmeTorq's Avatar
DIY
Here is a link, which is generic enough and still applies to 2k2 http://www.motorvate.ca/mvp.php/502
Make sure to:
1) use a silicates-free coolant, preferably Nissan's (it is expensive but still cheaper than replacing a water pump)
2) use destillated water, not tap water, to achieve the 50/50 coolant/water mixture
3) dispose of the old coolant properly
If you want to flush all the old coolant from the system, after draining the radiator, refill it with destillated water and run the engine for several minutes. Repeat this procedure until the water drained from the radiator looks clean. Since the cooling system capacity for the 2k2 is 7.25 qts and the radiator takes 4 qts, after draining the radiator one more time, there should still be enough water in the system to reach a near 50/50 coolant-water mixture if you just add coolant into the radiator.
Old Jul 6, 2004 | 12:50 AM
FishyMan's Avatar
i don't get the thread u posted bout the climate control. i have a '97 maxima.. it is manual? i guess where i slide the temp of the a/c..
Old Jul 6, 2004 | 06:53 AM
Colonel's Avatar
Old Fuddy Duddy
Basically turn your heat on. You want the heat on because it will open up the gate and allow the coolant in your heater core to be flushed as well. Regardless of automatic or manual climate control, turn the HEAT on full blast. If you are doing this in the summer time or a hot climate, make sure that during the test your Coolant temp gauge is at normal op temp for about 2-3 minutes to make totally sure its open.
Old Jul 6, 2004 | 03:15 PM
NizanDrivn's Avatar
The radiator flush looks simple enough....
Anybody have an ATF flush???...
Old Jul 6, 2004 | 06:24 PM
knapp9's Avatar
Check the Sticky's. The ATF flush "how to" is the 2nd from the top. I found it to be easier than flushing the coolant myself.
Old Jul 7, 2004 | 02:05 PM
RastaManMax's Avatar
I just did the rad flush myself a week ago, i used ~35L of distilled water and ~4.2L of Toyota Red OEM Coolant. I'd use either Toyota Red or Nissan Blue OEM if I was you, sure you pay more ($38CAD), but in the end you know it's done right vs. the Stealership who refills with Prestone or some other junk. Not only that, it's beyond easy once you start doing it, you can get almost all of old coolant out without damaging the rad and it's far cheaper.
LEMAR
Old Jul 7, 2004 | 05:28 PM
NizanDrivn's Avatar
thanks folks!
will attempt this wekend and repost....
Old Jul 12, 2004 | 06:53 PM
FishyMan's Avatar
how did it go?.. wanting to do a tranny flush as well..
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
RealityCheck
Oct 2, 2015 06:34 PM
Socalstillen
Sep 26, 2015 12:01 PM
