Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
replacing coolant w/ completely NEW coolant
Old Jul 8, 2004 | 07:18 PM
FishyMan's Avatar
i have a 97,
i want to replace the 'prestone' coolant w/ something better.
i know i have to flush out the entire thing. so do i
1) do the heater thing
2)drain radiator
3)refill w/ distill
4)run, and let cool
5) repeat cleaning till everything is all clear and drained out (w/o water in sys?)
my question is, after the whole thing is flushed out w/o dripping, how do i go about a pre-mix 50/50 adding into the system.? do i add some then turn on car and add along the way?
please chime in thanks..
*i've checked out the threads above and what not, i tried to search but i didn't have the privelages*.
Old Jul 8, 2004 | 07:24 PM
Mizeree_X's Avatar
Getting back to his roots
Originally Posted by FishyMan
i have a 97,
2)drain radiator
3)refill w/ distill
4)run, and let cool
Once the fluid being drained from the radiator is clear, fill the empty radiator with pure antifreeze. This should achieve a nearly 50/50 mix because there is still a fair amount of liquid in the rest of the system. This is what I have been told anyway.
Old Jul 11, 2004 | 11:11 PM
FishyMan's Avatar
cool.. so has it worked for u?.... ya i want to achieve 50/50 mix...
what coolant should i use?.. they say the toyota ones and honda blue are expensive...
which is the best one?
thanks
Old Jul 12, 2004 | 06:25 AM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread.php?t=278600
Old Jul 12, 2004 | 06:37 AM
Bobo's Avatar
There is a difference between draining the radiator and replacing its contents and flushing the entire cooling system properly. A competent radiator shop, if you check around, doesn't charge very much relative to a stealership. If they are doing the job properly they will flush the radiator, backflush the entire cooling system, pressure test the cooling system (which entails checking for leaks) and ensure the thermostat returns to normal operation when the engine is warmed up. For my money, I'll go to a radiator shop. I paid C$40 in May rather than C$110 to $120 at the stealership and I know the job has been done right and the coolant will be disposed of properly.
There is a long thread on this elsewhere currently.
Old Jul 12, 2004 | 07:45 PM
my99maxisnice's Avatar
Come on man, don't tease me...I can't convert Canadian to US
Old Jul 12, 2004 | 09:46 PM
FishyMan's Avatar
i am reading things up, but being a college student i try to do what saves me money, plus the joy in trying to learn and fix your car is priceless..
i don't think they will use distilled water but instead use tap... there's the external things to look at, such as nips, dings and what have u when someone else is working on the car, but then the equipment factor and tools come in...
i rather give it a shot, thanks for the ideas though..
bump !!
Old Jul 24, 2004 | 03:38 AM
FishyMan's Avatar
bump.. which coolant is good? i seen peak and extended life prestone brand.
so do i just pour pure anitfreeze after flushing?
thank.s
Old Jul 24, 2004 | 07:31 AM
SkoorbMax's Avatar
One thing I'll say is: Don't try and undo the engine block drain plugs. They are all but impossible to get at
Old Jul 24, 2004 | 03:52 PM
{-_-}'s Avatar
www.xe.com
Old Jul 24, 2004 | 03:57 PM
{-_-}'s Avatar
http://www.motorvate.ca/mvp.php/502
this link will show you step by step for your car...
Old Jul 24, 2004 | 06:10 PM
FishyMan's Avatar
COOL. seems okay. now all i have to do is find which coolant is good to use. any recommendation?
are prestone good? peak?
thanks..
Old Jul 24, 2004 | 06:50 PM
SkoorbMax's Avatar
thanks..
Well, just like you can spend $9 quart (or even more!) on a good synthetic oil, diminishing returns dictate that it's not a sound way to spend money. My take on coolant is get something decent (like prestone - I think that's what the dude on motovate uses too ), but you can spend more if you want - I believe that Nissan sells some.
If you have a ferrari enzo it may be worth getting the best money can buy, but i wouldn't bother going out of your way to get a highly expensive coolant. They all transfer heat, and one may last a little longer than another if you want to keep it in there for a long time, or slightly minimize oxidation of your metal, etc. but nothing major. Mix with distilled water.
Old Jul 25, 2004 | 11:14 AM
Chron!cRAGE's Avatar
I need to do this soon but I have a question. Motorvate's site says that the engine holds about 2 litres and the rad holds about 5 litres. So once the system is pure distiled water how will topping off the radiator with 100% coolant give a 50/50 mix of coolant and distilled water?
Old Jul 25, 2004 | 04:49 PM
FishyMan's Avatar
i want to know too :P
Old Jul 25, 2004 | 06:41 PM
Larrio's Avatar
The Definitive AE Master
thanks..
in the stickies there is a thread about coolant types. Don't use prestone or any general brand of coolant because there is a type of chemical/material in it not good for import cars.
Use either Nissan (green), Toyota (red), or Honda (blue) coolant
Old Jul 25, 2004 | 11:41 PM
FishyMan's Avatar
a guy is offering $10 for gal.. toyota red.. how can i make sure its real deal? beside it not being open.. is there only 1 toyota red brand?
Old Oct 24, 2005 | 12:52 PM
SSzretter's Avatar
Broken Drain plug Screw
So I followed the instructions on doing the drain and fill, and it all worked great, and that was a week ago. This weekend I notcied something on the driveway, and found I had a leak from the radiator - coming from the drain plug screw!! Looking closer, the screw was actually broken off!
I am not sure how this happened, and I ended up spending some cash and having a pro drill and re-tap it and put a new screw in (the dealership), but was hoping for some thoughts...
What is weird is that I remember when I put the screw in I was being careful not to crank it down too hard because it is plastic, so I dont know why it would have broken.... Not to mention the fact that I drove it 60+ miles a day for a week before I noticed any leak....
Balkins
Feb 1, 2016 12:45 AM
Justinmc760
Aug 23, 2015 03:10 AM
FlaMark
Aug 20, 2015 12:17 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
