Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Auto Trany Fluid ?
Old Jul 13, 2004 | 02:32 AM
maxGTRvq35de's Avatar
Auto Trany Fluid ?
What type of Auto Trany fluid do i need? i have a 2002 maxima. I am going to Switch to Mobil 1 Synth. but i dont know the specs on the trany fluid. any help would be great. thanks guys, oh yea do we have trany filters advanced said i dont show one in there computer?
Old Jul 13, 2004 | 03:46 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
our tranny fluid is dexronIII/mercon. the mobile 1 is compatible with our stock fluid so they can be mixed. the computer @ advance auto was right because we have a screen, not a filter. they do sale a tranny pan gasket with the screen @ advance, they took 1 day to get mine in. i use mobil 1 since its easy to get @ pepboys
Old Jul 13, 2004 | 04:15 AM
2002 Maxima SE's Avatar
Yup, Mobil 1. I switched mine out twice. Once at 20K and again at 30K (drain from pan then refill with 4.5 qts).
Make sure you only refill 4 qts, drive, check level and then add. On my second change it only took about 4 qts (didn't let it drain long enough I guess) and I overfilled by about 1/2 a quart.
Old Jul 13, 2004 | 04:41 AM
thanks guys im going to the track sat. and i wanted to do it before then so you guys came through. thanks again
Old Jul 21, 2004 | 10:32 AM
00Max00's Avatar
I have drained and refilled the 2k with almost 6 quarts of M1 ATF.
Old Jul 22, 2004 | 09:11 AM
BluFlame's Avatar
I dropped the pan and refilled with 6qt of M1. I have a cooler.
BobTX10
Oct 7, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
