Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Techron
Old Jul 29, 2004 | 12:24 PM
smoon629's Avatar
Techron
ive been reading and hearing about the FUEL INJECTOR CLEANER called "TECHRON CONCENTRATE." i want to use it but i dont know if i particularly need it. i do a lot of city driving but ive only got about 36,700 miles. will i feel any benefit from using this, even at my mileage? thanks for the input.
Old Jul 29, 2004 | 12:30 PM
my99maxisnice's Avatar
I gained 1 mpg from it...worth the 7 bucks.
Old Jul 29, 2004 | 01:42 PM
Mizeree_X's Avatar
Getting back to his roots
I dump a bottle in every oil change. Good preventative maintenance IMHO. Never noticed any dramatic change right after using it but I've always had a smooth idle and good gas mileage (after I replaced my busted O2 sensor, that is).
Old Jul 29, 2004 | 09:10 PM
GimmeTorq's Avatar
It's good stuff, the only fuel system cleaner I use in my Max.
http://www.chevron.com/prodserv/fuel...gas/tech.shtml
Old Jul 30, 2004 | 04:27 AM
SkoorbMax's Avatar
Never noticed a change, but I have had it recommended by a high end mechanic on another forum. In the majority of cases you're doing nothing, or even harm, with additives to oil and things of this nature, but the consensus I had when I looked into fuel injector cleaners some months ago was an almost uniform thumbs up on them. Chevron Techron is an inexpensive one from walmart. Another good one is BG44K, though it will cost you $20/can. I used that in my 00 Max, but the cheaper Techron in my 97. I can't say which is actually better, so I'll probably use techron in the future.
One idea I'd heard was to change your fuel filter before hand, if possible, as somebody had brought up a concern that a fuel injector cleaner could remove some of the deposits from your fuel filter (and you don't want that), though I'd seen this idea posted only a couple of times, and the cleaner and filter may be dealing with separate substances, so as to make the argument moot.
Old Aug 22, 2004 | 11:07 PM
sagamax's Avatar
Give me a Bud Light Holmes
which should i used the techron or the sea foam....it seams everybody on here is hyped about the sea foam
Old Aug 23, 2004 | 07:26 AM
Mizeree_X's Avatar
Pull Seafoam through your intake manifold via a vacuum line and dump Techron in your gas tank. That's how I do it.
Old Sep 20, 2004 | 09:47 AM
flthere's Avatar
Should we replace fuel filter before or after dumping a can of Techron ?!?
Thanks.
Old Sep 20, 2004 | 10:16 AM
SkoorbMax's Avatar
"Knock Knock"
"Who's there?"
"Combustion Chamber Deposits"
LMAO!
polvoronn
Nov 6, 2005 07:31 AM
kcryan
Oct 8, 2005 07:22 AM
JwaxMax99
Jun 30, 2005 12:28 PM
smoon629
Aug 30, 2004 02:32 PM
infinitiblast
Sep 14, 2003 02:36 PM
