Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Those going for reasonably long intervals - do you change the oil filter half way?
Old Aug 26, 2004 | 06:23 AM
SkoorbMax's Avatar
I'm thinking of going 8-10k with mobil 1. How essential is the oil filter change, really? Schedule 2 in the manual says 7500 for oil and filter - and that's conventional oil.
Old Aug 26, 2004 | 09:53 AM
{-_-}'s Avatar
you should change the filter about 1/2 way into that 8-10k.
Old Aug 26, 2004 | 11:14 AM
schmatt's Avatar
The filter will always wear out before any synthetic oil. This is a must if you are planning on going longer drain intervals. Once the filter is clogged up, it no longer filters the oil. This is why it needs to be changed before the oil. Will only require a small top off on the oil once the filter is replaced.
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
