Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Checking ATF level...(long)
Old Oct 17, 2004 | 06:05 PM
GodsmackMAX's Avatar
Hello guys,
I recently installed a VB mod in my '97 GXE. I drained the fluid into containers (milk jug, pepsi bottle) so I could measure it and put the correct amount back in. Well, it ended up being about 6 1/2 qts if I recall correctly.
Anyways, I have been watching the level for the past week or so. When I first start up the car and check it, the level is a little below the first notch on the edge of the dipstick. After driving it for 30mins or so, I check it again, and it is a little below the first line before the crosshatch (on hot side).
I put some more in once, and got it in between the two notches on the cold side, then the next day it was back down again. Now I have checked for leaks and can't find any to save my life. It was parked over a concrete driveway this weekend and there was not a bit of fluid on the driveway. When I was putting my pan back in, I think two of the bolts may have stripped as they just kept turning. Torqued them all to 6-7.
Could it possibly be burning off some of the new fluid, or is it just so low because it has not heated up yet? Oh, and is it okay to add fluid while it's running?
Sorry for the longness...
Thanks,
drew
Old Oct 18, 2004 | 05:08 AM
ttt....1234chars
Old Oct 18, 2004 | 05:52 AM
mzmtg's Avatar
Minister of Silly Walks
Follow the procedure for checking the fluid level in the Haynes manual.
The first step is: warm up the engine and trans to regular operating temp....
Old Oct 18, 2004 | 01:46 PM
foodmanry's Avatar
Da Roller Coaster!
This will take longer if you have a tranny cooler installed. Probably about 20 to 30 minutes of city driving. Make sure you go through all the gears. Engine has to be running when you check it. Best to check it when its at operating temperature. A cold check is almost useless.
matts95max
Apr 23, 2025 10:44 AM
mvm062
Nov 30, 2020 09:00 AM
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
