Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Amsoil Series 2000 Synthetic Gear Lube
Old Oct 25, 2004 | 08:20 AM
NikaL's Avatar
I've been using Red Line MT-90 for 3 years now. But my tranny died. Not because of the oil. Bearings went out, most likely preload was wrong. I'm getting a new tranny (20th anniverasy w/LSD) and want to use something that protects better. I've been reading good things about Amsoil and I see people use Series 2000 Synthetic Gear Lube. But, i'm confussed because 5th gen tranny requires GL4 grade gear oils. 2k series is GL1-GL5. Would this oil be ok? Will it damage syncros?
Also, any sugestion where can i buy regular GL4 grade lube. I need it for first 100 miles to break in the tranny
Nik
Old Oct 25, 2004 | 08:32 AM
nicks79's Avatar
REDLINEOIL.COM has a list of dealers where you can buy. GL-4 is pretty hard to find. Pepboys and Autozone don't have it. And 2000 maxima uses only GL-4, nothing else. Just put in MT-90 and what a difference after driving with wrong lub for a week.
Old Oct 25, 2004 | 08:52 AM
ajahearn's Avatar
Api Gl
I thought that transmission oil API's worked the same as motor oil, which is to say that higher ratings can be substituted for lower ratings. So in this case although GL-4 is specified, GL-5 is acceptable. I would really like to know if this is not true as I was planning on changing my 6spd MT (w/out LSD) this coming weekend and I bought the GL-5 stuff.
All I could find on ratings indicated that GL-5 has some special properties for LSD transmissions. The article did say that substituting something different when GL-5 was required could result in damage. But that would make sense as there is no GL-6 (at least none listed).
Old Oct 25, 2004 | 09:02 AM
NikaL's Avatar
Not sure about 6-speed, but 5-speed has bronze syncros. GL-5 has corosive agent and eats up sofl yellow metals. NOT GOOD.
Also, nicks79 thanks, but I know where too get Red Line. I've been using it for 3 years. go to www.myoilshop.com. What i need is conventional gear oil. You're not supposed to use syntetic oils when you break in trannies or engines. at least that what mechanic told me once
Old Oct 25, 2004 | 09:36 AM
Progress's Avatar
It's business time.
PM "iwannabmw" he sells it, that is where I got mine. BTW, I feel almost no difference in shift feel over stock fill. Whether there is less damage or not, I don't know.
Old Oct 25, 2004 | 11:09 AM
spirilis's Avatar
Yes, do NOT use GL-5 in a Nissan tranny. It contains a sulfur-based compound that will corrode the synchros.
I believe Amsoil Series 2000, while it is GL-5 compliant, does not contain this sulfur-based compound for whatever reason (Amsoil's fluids are generally engineered well, so they probably found a substitute that works better)
Redline MT-90 is very well suited.
Old Oct 25, 2004 | 12:11 PM
Progress's Avatar
It's business time.
This corresponds with the info iwannabmw gave me.
Old Oct 25, 2004 | 01:29 PM
spirilis's Avatar
I am not 100% sure if this rule of thumb applies to ALL manual transmission Nissan vehicles, but every model I've read in any depth seems to follow this guideline (NO GL-5 due to brass synchros)
Old Oct 25, 2004 | 02:48 PM
ajahearn's Avatar
I got this from my brother. It appears that the GL-5 stuff can be very hazardous to your MT. It's interesting to note that there is a redline GL-5 that is okay (I'm not sure how as it seems like the very additives at issue are the ones that cause problems).
Old Oct 25, 2004 | 02:49 PM
ajahearn's Avatar
Forgot to add the link. http://www.ultimatesubaru.net/forum/...p/t-15000.html
Old Oct 25, 2004 | 03:56 PM
spirilis's Avatar
It's some kind of sulfur-based additive that does the trick. Most oil manufacturers use it for a certain purpose (extreme pressure tolerance of some kind maybe?), and this compound is probably the best, or at least cheapest, for the job. But some oil manufacturers, e.g. Amsoil and maybe Redline, have found formulas that meet the spec without using that compound. It's just that 95% of the GL-5 gear oils out there probably have it in it, so as a rule of thumb, you don't use GL-5 at all.
Old Oct 25, 2004 | 05:40 PM
kingrukus's Avatar
no more maxima...
Im using it and it is GL2 thru GL5 rated...hasn't eaten anything yet (hopefully)
Old Oct 25, 2004 | 08:43 PM
haysdb's Avatar
FYI, the AMSOIL Series 2000 gear lube is being replaced with a new product, Extreme Gear, which is GL-5 only, and not appropriate for our Maximas. If you want the Series 2000, move quick before stocks are depleted.
AMSOIL does have another GL-4 gear oil, ALU (also known as AGT), which is labeled as "marine gear lube", but is also "auto spec GL-4". Link to product page.
Old Oct 25, 2004 | 08:46 PM
kingrukus's Avatar
no more maxima...
Oh crap....
Does anyone know the shelf life on this oil? I am thinking of buying another set and then having it sit for a year or 2.
Old Oct 27, 2004 | 07:36 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Originally Posted by kingrukus
Oh crap....
The oil has an indefinite shelf life...it won't go bad if kept on-hand. I have checked some of the AMSOIL Product Centers for customers, and as of last week, they had some of the Series 2000 remaining. In case you didn't know, there is a Product Center in Toronto..recommend you give them a call and see if they have any left in stock.
Old Oct 27, 2004 | 07:43 PM
kingrukus's Avatar
no more maxima...
Thanks for the information. I have visited an amsoil dealers in Missisasuga ON Canada, and I may be purchasing another set through them.
Old Nov 9, 2004 | 03:05 PM
RA030726's Avatar
I'm nutty for Nissans
all i can find locally is Series 2000 Synthetic Gear Lube 75W-140 Product Code: TGO. Will that eat my syncros? http://www.performancemotoroil.com/S...r_Lube_75W.htm
Old Nov 9, 2004 | 03:07 PM
Jeff92se's Avatar
I'm needing a caw
Here is how you find out:
1) Find out what GL rating your tranny specifies
2) Look at the link you provided and see if this meets the GL rating your tranny requires.
Old Nov 9, 2004 | 03:36 PM
MrGone's Avatar
Amsoil 75w90 is GL4 certified
Old Nov 9, 2004 | 03:46 PM
RA030726's Avatar
yes i can read gl2 through gl5 BUT i wanted to know if it had the "bad" additive that eats yellow metals. No one has talked about the TGO.
From what i can see its the same as TGR (75W-90) but with a higher temperature range and viscosity.
Old Nov 9, 2004 | 03:58 PM
Jeff92se's Avatar
I'm needing a caw
If it's rated gl-4, then it's okay. But you want to make 100%? Give those guys a call and see what they say. ie.. Amsoil tech service. That's better than relying on anyone's opinion here. Then you can report back to us.
Old Nov 9, 2004 | 05:03 PM
RA030726's Avatar
hmm, good point. i'll do that
Old Nov 10, 2004 | 12:45 PM
RA030726's Avatar
Straight from the email:
To: Jon Sutter
Thank you for contacting AMSOIL with your concerns.
In response to your inquiry, in applications such as this that request an API GL-4 rated gear lube, we suggest the use of our AMSOIL Synthetic 80W90 Gear Lube (AGT).
AMSOIL Synthetic 80W90 Gear Lube (AGT) is sold in gallon size containers and larger. If more convenient, our AMSOIL Synthetic 80W90 Lower Unit Gear Lube (ALU) may also be used. It is available in smaller containers including quarts. It may be used in any application that AGT is used in. These are both straight GL-4 products.
The 75W140 is not recommended – too heavy.
Thank you again for the opportunity to respond to your concerns. As always, please feel free to contact us again if we can be of further assistance.
Sincerely,
Jim Van
AMSOIL Technical Services
So the Series 2000 Synthetic Gear Lube 75W-140 Product Code: TGO is a no go.
Old Nov 10, 2004 | 12:52 PM
Jeff92se's Avatar
I'm needing a caw
Nice info. I'm going to guess it's the 140weight and not the rating that prevents them from recommending it.
Old Nov 10, 2004 | 12:55 PM
Mizeree_X's Avatar
Getting back to his roots
I bought that marine gear lube, and didn't like it. In cold weather, it got very viscous and made shifts difficult. I have since put in MT-90 and love it.
I actually have a jug of the marine lube, about ~3 qts left if a local guy wants it as a quick fix.
Old Nov 13, 2004 | 09:52 PM
RA030726's Avatar
I said F it and just got Mobil 1 synthetic cuz its available local.
Old Nov 14, 2004 | 06:18 AM
spirilis's Avatar
Mobil 1 synthetic GL-5 I don't think is safe for Nissan trannies... how does your tranny feel?
PS, adding to the discussion... the other day I switched my tranny to Amsoil Series 2000 GL-5 75W-90. I believe I read somewhere that this is actually safe, despite the GL-5 rating. Anyway, I am impressed. First thing I noticed is that the car seems to "roll" easier, or at least maintains its momentum a little better than the old Redline MT-90 I had in there. Shifting wasn't any better or worse at first, but now I think it's becoming a little smoother. The most important thing I noticed is that the car seems to soften out small "jerks" (e.g. from clutch operation) somewhat, making the general experience of city/town driving less annoying. It's kinda hard to explain, almost as if the oil is absorbing shock better than the old MT-90 did or something. I am thoroughly impressed.
Old Nov 14, 2004 | 08:11 AM
RA030726's Avatar
i have not added it yet. IM doing the clutch thanksgiving, so it will be put in then. According to http://www.forums.maxima.org/showthread.php?t=225766
the Recommended Gear Oils include:
Amsoil TGR Series 2000 75W/90
Redline MT-90
Mobil 1 75W/90 Synthetic Gear Oil
Redline MTL (for extreme Northern climates, Canada area, etc.)
so I should be good. If someone can prove Mobil 1 is no good, I'll get the MT-90 (though I really dont want it). I would like the Amsoil but i cant get the stuff locally and it really bugs me.
Old Nov 14, 2004 | 09:42 AM
DAVE Sz's Avatar
Hooooooonda.....
I have a gl4 marine lube and I like it. It's been in the 20s here already and it's very smooth. At first there is some notchiness but I think it's clutch chatter or rbad allignment.
Old Nov 15, 2004 | 07:36 AM
spirilis's Avatar
Huh. I didn't know Mobil 1 75W-90 synthetic gear oil was acceptable. Let me do some google searching, I thought I read somewhere that Mobil actually informed someone that it will cause corrosion...
If Mobil 1 is acceptable, then I might have to try it someday to compare. I've always been hesitant to change my gear oil because I was too lazy to order the stuff online, although recently I found a local Amsoil dealer so I purchased my Series 2000 75W-90 through them this past week. (probably not at the best price, but I was in the mood to change the gear oil so I did it)
Old Nov 15, 2004 | 01:07 PM
RA030726's Avatar
if you find thats its not good I will take it back and buy something else. I have an amsoil catalog, Napa sells it, but they didnt have what I needed. I said screw it an bought the Mobil 1. I may just get the MT-90 if the Mobil is junk.
Old Nov 15, 2004 | 01:08 PM
Jeff92se's Avatar
I'm needing a caw
Mobil 1 = GL-5 = will eat up your synchros in a hurry.
Old Nov 15, 2004 | 01:16 PM
spirilis's Avatar
Amsoil Series 2000 75W-90 is GL5 too... but I thought it was acceptable? Either way, my shifting feels a tad better with it in there...
Old Nov 17, 2004 | 05:12 PM
AMSOIL Series 2000 75w-90 gear oil is rated GL-2 thru GL-5, so it is safe to use in our GL-4 applications.
Old Nov 17, 2004 | 07:44 PM
RA030726's Avatar
are you sure the Mobil 1 synthetic has the bad additive? gad damn it IF it does I will get the redline MT-90.........
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Fbana41
Aug 29, 2016 12:18 PM
