Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Specifically why shouldn't synthetic oil be put in 100K+ mile engines 4 the 1st time?
Old Nov 2, 2004 | 04:08 PM
  #41
Jeff92se's Avatar
I'm needing a caw
This pretty much says it all.
1) You didn't even read or even understand the article. (Even thought it was done in clear every day terms
2) You would rather believe some CEO that most likely doesn't know anything about engines or oil.
Originally Posted by kcryan
2 things we dont have motorcycles and read the first sentence. again do what you want
Old Nov 2, 2004 | 04:10 PM
  #42
kcryan's Avatar
i know somone with our same engine who last i knew had 190k on it and always used dinos and im sure there are people who have more than that both on syn and convent. but he never had a real problem and it was still running strong. he was happy with it and im betting his oil costs were much less than yours. but i could be wrong
Old Nov 2, 2004 | 04:12 PM
  #43
Jeff92se's Avatar
I'm needing a caw
1) How do you know it wouldn't have been in even better condition with Synthetic?
2) I never said dino wouldn't be fine (if you use the RIGHT dino oil)
3) Again so many assumptions. How do you know what I use, how much I pay for it and how much it costs me per mile of use? So yes, you could be VERY wrong. At least you are correct in that
Old Nov 2, 2004 | 04:17 PM
  #44
kcryan's Avatar
it might have been in better cond. with synthetics but it was in good or great cond. as it is and personally i dont think my car will make it past 250k the engine might but the car itself wont.
  #45
kcryan's Avatar
and what is the correct dino in your humble opinion?
and if you dont mind me asking what kinda oil do you use and what are ur intervals?
Old Nov 2, 2004 | 04:21 PM
  #46
Jeff92se's Avatar
I'm needing a caw
What I use is mentioned in the article
I actually change pretty often at 3-4k. But I used to use Amsoil and extended the change intervals
But my choice of oils is NOT related to this conversation. Nor does it change the points made or the facts given. When I turbo, I WILL switch to a quality Synthetic. Superior film strength, lack of sludge and overall superior protection will be mandatory.
Old Nov 2, 2004 | 04:22 PM
  #47
kcryan's Avatar
yes a turbo is a totlly different subject and i agree on synthetics for that
Old Nov 2, 2004 | 04:28 PM
  #48
philly96maxima's Avatar
castrol gtx & Hastings filter
Old Nov 2, 2004 | 04:31 PM
  #49
kcryan's Avatar
agreed
Old Nov 2, 2004 | 04:48 PM
  #50
Jeff92se's Avatar
I'm needing a caw
That is fine guys. But it wasn't part of Harris's original question.
Old Nov 2, 2004 | 05:14 PM
  #51
Ant96GLE's Avatar
Wow i actually read that whole article.. the only real answer that I can give for people saying you shouldnt change to synthetic after 100k (which is pretty much unsubstantiated) is the fact that synthetics have different detergents in them than regular oil... the oil is the same viscosity but it will clean out all the sludge around your valves and rings... the same crud that may be "sealing" that valve when it closes is now gone.
Old Nov 2, 2004 | 05:37 PM
  #52
kcryan's Avatar
doesnt GTX have a good additive package? i believe that is one of the reasons many of us love it so...
Old Nov 2, 2004 | 06:50 PM
  #53
deezo's Avatar
I'm running Mobil 1 Synthetic and my intervals are 10,000 miles. I currently have 154,000 on the engine.
Old Nov 3, 2004 | 12:56 AM
  #54
Otis_Speeding
my GLE runs just fine...all I do is spit in the engine every month or so to top it off. lol
Why are you guys arguing so much about oil? We drive Maximas remember? The VQ engine is indestructable. The freakin thing will run on a few sticks of butter. I may dump in a few cups of cream cheese. It will work like that dura lube engine treatment stuff and seal up all the spots with wear and tare.
Old Nov 3, 2004 | 01:01 AM
  #55
Otis_Speeding
One more thing...
Most people will go out and buy another car when a simple thing like oil has such a huge impact like you guys make it out to be.
Old Nov 3, 2004 | 06:19 AM
  #56
SkoorbMax's Avatar
It's a dying opinion, that cars shouldn't be switched late. There was merit to it in the past, but from what I understand the new seals/gaskets in all cars made after a certain time allow even cars with high mileage to take synthetic without issue. FWIW I've been on it for 10k miles, since buying my 97 with its 77k, and there is zero leaking so far in 6 months.
Old Nov 3, 2004 | 08:52 AM
  #57
Jeff92se's Avatar
I'm needing a caw
Again false. Remind me not to buy any used cars from you
Old Nov 4, 2004 | 10:43 AM
  #58
Pappa Grande's Avatar
I have 246,xxx on my 95 SE. Owned it since 70,000. I have changed back and forth several times (usually using synthetic during the winter). I have never had a problem. I have one very simple measure of my engine's condition...I consitently get 425 plus miles to a full tank. Not scientific and clearly not the best test, but my car has treated me very well.
Old Nov 4, 2004 | 11:44 AM
  #59
Hey!...is that a rod knock from your block?
Old Jul 30, 2008 | 06:56 AM
  #60
timandleighsa's Avatar
i use syntec
Old Aug 3, 2008 | 05:15 PM
  #61
carsarecool's Avatar
you almost made it 4 years w/out anyone posting in this thread lol
since i just read the whole thing I may as well comment. I believe he was talking about when oil is "dirty" say 4, 5, maybe 6000 or maybe even 10000 miles, depending on the additive package, oils oxidize at different rates, and they get contaminated from combustion blowby. Moisture, among other things such as unburned fuel can end up in oil as well, thats why if youve ever seen an oil analysis report there is a spot for these things on the spec sheet. condensation(from moisture, and the additive package thats gradually breaking down) causes acids and sludge, as far as i've heard.
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxgig
Aug 18, 2015 09:17 PM
sc10692
Aug 9, 2015 09:37 AM
yat70458
Aug 3, 2015 01:16 PM
