Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
30K miles on Redline D4 ATF, should I stick with Redline? add Lubeguard?
Old Nov 10, 2004 | 09:01 AM
nm's Avatar
nm
It has been about 30K since I had my transmission flushed with Redline D4 ATF fluid. I was going to do a drain and fill with with Redline but it looks like most people recommend Amsoil.
Do you thinks it makes sense to switch to amsoil (is there a big difference between Redline and Amosil ATFs)?
Also, I've read a couple of posts about having to add LUBEGARD friction modifier to Amsoil and Mobil1 to get the to perform like nissanmaticD, does this apply to Redline D4 fluid as well?
Old Nov 10, 2004 | 11:06 AM
Love_00_Max's Avatar
Most of the syn fluids come from good base stock possibly GroupIII+ and are extremely tolerent to breakdown and oxidation (that is why you can take it to 60K). They may contain FMs but if I were you I would talk to the customer rep and ask them before putting additional FMs into the tranny. In my case I was sure the dino DexronIII fluids don't have FMs and NissanMaticD is a friction modified fluid -- I went ahead and added Lubegard Black into it. FYI, my chance encounter with Mobil1 Syn ATF was unpleasant.
Old Nov 11, 2004 | 04:41 AM
NYC TAR's Avatar
Amsoil is a friction modified fluid, to meet spec for Honda, Toyota and other cars.
I don't know about Redline D4.
Old Nov 11, 2004 | 08:45 PM
GimmeTorq's Avatar
Could you elaborate?
Old Nov 12, 2004 | 04:32 AM
nm's Avatar
nm
What would be the signs that an ATF fluid that is not highly friction modified is being used in a transmission that requires one?
Old Nov 12, 2004 | 05:32 AM
NYC TAR's Avatar
^^^My other car is a 95 accord EX, that would require Honda highly friction modified ATF. The tranny would bang into gear and it would take 3-5 SEC delay shift, after you let off the gas. If won't shift unless you let go of the gas. When put Honda ATF in to the car, it fixed 95% of the problem. I believe it should have the same problem on Nissan. My next ATF change on my Nissan would either be used with honda type H, or AMOIL ATF,cause right now it bang into gear with Stock ATF, when the tranny is hot . I believe that Nissan don't put have enough friction modified fluid,
The only time I used Mobil1 was way back more than 18 months ago and when I did a drain and refill (not a flush) my tranny got real hot (and it was not overfilled) and like any transmission, Nissan's tranmission shifts gets real wierd when the transmission fluid gets hot.
FYI, there have been well documented cases where syn ATF's run hotter than dino regular ATFs. Since then I have flushed with Chevron DexronIII and stopped monkeying around with my tranny for good!!!!
On the other hand I have had many folks in the forum swear by Mobil1 with excellent results -- on hindsight I may have been the few unlucky folks who haven't yet plunged into the syn fluid world.
Max139617
Oct 19, 2016 11:34 AM
markevans999
Oct 25, 2015 08:27 AM
LtLeary
Sep 14, 2015 12:33 PM
