Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Switching between syn. oil & regular oil
Old Dec 8, 2004 | 03:05 AM
fadeaway's Avatar
Go Hokies!!
Synthetic oil was used the last 3 times or so on my 99 138k mile maxima. Yesterday, I went to get another oil change, but failed to mention synthetic, so they did regular.
Am I screwed?
Thanks.
Dan
Old Dec 8, 2004 | 03:52 AM
chenzarino's Avatar
not screwed at all, but it is usually ideal to stick with one type. Regular or Syn.
Old Dec 9, 2004 | 03:48 PM
Maximeyez's Avatar
That was not too smart!!!
Once you switch to synthetic oil you MUST ALWAYS use synthetic. Synthetic oils have an additive in them that will cause your engine seals to swell. If you change back to regular oil those seals will begin to shrink and your engine will soon begin to leak oil like mad. Give it about 3-400 miles before you start to notice oil leaks. Another problem that can occur is that your compression will drop because you have created leaks in the engine. I would go back right away and have the oil dumped and get it replaced with synthetic. It may cost you some money now but it will cost you a whole lot more in the future if you don't have it done!!!!!!
Old Dec 9, 2004 | 04:48 PM
kcryan's Avatar
if hes right id flush it pronto
Old Dec 9, 2004 | 05:15 PM
jay929rr's Avatar
really? wow i thought no harm was involved with switching back and forth?
Old Dec 9, 2004 | 06:43 PM
southeast_first's Avatar
it's not going to hurt anything to switch back. i wouldn't recommend doing it repeatedly, but you're not going to kill your engine or anything. some older syn oils had problems switching back and forth, but as long as you stick to the major brands, you'll be fine.
a better question is, why aren't you changing your own oil?
Old Dec 9, 2004 | 07:08 PM
The_Bomb's Avatar
There isn't. You will be fine. The myth about once you switch to synthetic you must always use synthetic is just that, a myth. Run that oil for a regular change interval and then use synthetic again if you want.
Adam
Old Dec 10, 2004 | 10:46 AM
NismoMax80's Avatar
SuPeRmOd
LIAR!!!!
you'll be fine. Just switch back after 3k. Syn. cleans better, causing some older engine to leak by removing the grime that prevented already present leaks.
But he was already using Syn, so that doesn't even matter.
It is far better to top off with dino then drive around w/o enough oil until you find the Syn.
If this was a problem, Mobil 1 and others would require a "Syn Only" warning so this mishap wouldn't occur.
James92SE
Oct 8, 2015 04:57 PM
foodmanry
Sep 24, 2015 12:02 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ag90fox
Sep 9, 2015 12:22 PM
