Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Low Oil Pressure?
Old Dec 10, 2004 | 01:32 PM
Wiseman's Avatar
Low Oil Pressure?
I have a 97 Maxima and for some reason when I first start up the car the Oil pressure is fine. But after 10 minutes of driving my Oil pressure goes to -0-
Any Ideas on what could be causing this problem? I reciently changed my Filter and Oil. So all fluid levels are fine....
Old Dec 21, 2004 | 06:45 PM
Torkaholic's Avatar
How are you measuring your o/p? By guage or the light? Of course, in either case, you'll want to get an immediate expert evaluation of what's going on, as lack of o/p can be catastrophic in seconds. If you're using a guage, and it's all the way to zero with no secondary indications of o/p drop, then perhaps it's a guage system malfunction. Could be the same for the light. Also, some cars manuals actually advertise that some flickering of the o/p warning light is OK at a hot idle. For my car (G35) there is no indication that Nissan thinks a flickering o/p light is OK, again, at least for my version of the VQ. Finally, another question: what oil are you using? If it's an especially thin one, or perhaps a poor quality dino that is shearing down out of grade, it may be so thin that when hot, your car is not able to maintain proper pressure.
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
thenewguyy
Sep 12, 2015 11:12 AM
ag90fox
Sep 9, 2015 12:22 PM
