Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
what causes drain plug to leak?
Old Jan 21, 2005 | 02:10 PM
jay929rr's Avatar
All of a sudden my drain plug is leaking a bit, the washer looks in good condition and i have dino oil in there.
Old Jan 21, 2005 | 02:12 PM
Jeff92se's Avatar
I'm needing a caw
You need a new copper drain plug washer. Or it's loose
Old Jan 21, 2005 | 02:37 PM
jay929rr's Avatar
the one i have on there is silver, so thats the wrong one?
Old Jan 21, 2005 | 03:01 PM
Bonka's Avatar
Schnell kaputt
I have not used the washer a few times and it doesn't leak.
Check the threads on the drain bolt. My other car has this problem. Replaced the bolt and leak is gone.
The crush ring washer should fit very snug over the threads of the bolt.
Old Jan 21, 2005 | 08:08 PM
schmatt's Avatar
Make sure you have it torqued properly too.
Old Jan 22, 2005 | 07:02 PM
Torkaholic's Avatar
Yeah, this is more critical than you might expect. Years ago, I accidentally over-torqued the drain plug in the Civic I owned at the time, and broke the threads in the pan, not the bolt. That definitely causes leaks and is a huge PITA to remedy.
Old Jan 22, 2005 | 08:08 PM
2002 Maxima SE's Avatar
Pepboys carries a line of drain plug washers in silicon and gasket material. Worked for my wife's leaking 93 Sable.
knight_yyz
Nov 6, 2015 02:34 PM
foodmanry
Sep 24, 2015 12:02 PM
JoshG
51
Sep 21, 2015 10:41 PM
markevans999
Sep 10, 2015 04:29 PM
ag90fox
Sep 9, 2015 12:22 PM
