Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Does amsoil make a GL4 compliant synthetic manual transmission oil?
Old Feb 19, 2005 | 03:07 PM
kingrukus's Avatar
no more maxima...
I hear the severe gear oil is not GL4 approved and they do not make the Series 2000 stuff anymore. Any other options from Amsoil?
Old Feb 19, 2005 | 03:21 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Yes, AMSOIL still offers AGT and ALU, both 80w-90 GL-4 lubricants. See my post in the Group Deals section for Dealer Cost offer.
Old Feb 25, 2005 | 11:04 AM
kingrukus's Avatar
no more maxima...
Do you know how this stuff compares to the Series 2000 stuff? Also are these lubricants synthetic?
Old Feb 25, 2005 | 01:22 PM
kingrukus's Avatar
no more maxima...
Ed,
I noticed on Amsoil's website that the AGT is rated as being GL-4 compliant but the ALU only made reference to the GL-5. Are you sure ALU is also GL5? ALU would be easier to buy as they come in the regular 946ml bottles where as AGT comes in a much bigger container.
Old Feb 25, 2005 | 01:51 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
My impression from Amsoil and BITOG posts was that the SVG can be used in GL-4 apps......
Old Feb 25, 2005 | 01:59 PM
CCS2k1Max's Avatar
The question is, will 80W90 be light enought for a good Toronto winter night? I shied away from 80W90 in Chicago going for the extra 15 or so degrees in pour temps and peace of mind a 75W90 gear oil gives. JMHO.
Old Feb 25, 2005 | 02:08 PM
kingrukus's Avatar
no more maxima...
Yup viscosity also had me worried with the 80w90 vs 75w90. Maybe it is wise that I stick to something else because of the temps we experience. Any idea on what the 80w90 ideal temp range is?
Old Feb 25, 2005 | 02:10 PM
Jeff92se's Avatar
I'm needing a caw
If it's synthetic, I think you are okay. If you compare an sythetic to a dino type gear oil, the synthetic keeps it's true viscosity MUCH better than dino. When dino gear oil is cold, man who knows what the viscosity starts out at.
Old Feb 25, 2005 | 02:35 PM
CCS2k1Max's Avatar
The AGL pour temp is -33°C (-36°F) per their website. Windchills can beat that around here.
Old Feb 25, 2005 | 04:57 PM
mansurxk's Avatar
windchills arent factored on inanimate objects, windchills are only taken into account with mammals since we radiate heat and we get weak if too much heat is lost in a short amount of time. you want ambient temperature with regards to what oil you choose.
Old Feb 25, 2005 | 05:13 PM
Ed,
ALU is GL-4 rated...
Old Feb 25, 2005 | 05:29 PM
Some of us have entered into this debate already. The SVG is labeled GL-5...it's not clearly labeled GL-2 thru GL-5 as were the oils it replaced. However, the Product Data Sheet for SVG says it "can be used in rear axles where GL-4 is recommended." I called AMSOIL Tech Services for clarification and they told me that although some folks were using this oil in transaxles, the best choice would be GL-4 AGT (or ALU) as the SVG contains a more "aggressive" additive package than the oils it replaced. For that reason I have not been recommending folks use SVG for our applications...
Old Feb 25, 2005 | 05:47 PM
Unless Nissan specs something different for Canadian vehicles, my factory service manual for the '98 says use "GL-4 80-90 ONLY". That being the case, AGT or ALU should be your oil of choice.
Old Feb 25, 2005 | 05:49 PM
irish44j's Avatar
retired moderator
forget this confusion and try some Redline MT-90.....smooth as butter shifts.....
Old Feb 25, 2005 | 06:06 PM
kingrukus's Avatar
no more maxima...
Is there any major difference between either ALU or AGT?
Old Feb 25, 2005 | 06:20 PM
ALU and AGT are essentially the same products, just targeted for different markets. They have the same performance specs, they are both approved for automotive GL-4 applications and the tech data sheet lists it as "AGT, ALU" with one set of performance numbers. AMSOIL Tech Services has told me that ALU contains slightly more water emulsifiers than the AGT since the ALU is marketed for marine applications, and that's the only difference...
Several folks have purchased a gallon of AGT and one quart of ALU...and that seems to be working out fine for them...
Old Feb 26, 2005 | 05:41 AM
CCS2k1Max's Avatar
I used the term windchilll because it's a term most non technical people can understand. Does convection cooling of the transmission case in a very cold windy night sound better? The gear oil won't know the difference, only that it is cold. -33°C is a possibility in Toronto.
Old Mar 10, 2005 | 01:59 PM
MiniRX7's Avatar
Great..
I am running the SEVERE SERVICE in my 2003 6 speed maxima... And now its the wrong oil? I spoke with tech service at AMSOIL and he said it should be fine running this..
Should i swap it out?
Old Mar 15, 2005 | 09:56 PM
Mr.Duck's Avatar
i got the gallon of ALU, and quart of AGT from ED, and it works fine, havnt had any problems so far, and yes they are BOTH GL-4
BTW- Buy from Ed, great seller, great customer service, and i got my oil 3 days after i ordered
CorollaULEV
30
Aug 9, 2021 08:11 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
ffcbairn
Aug 16, 2015 09:29 PM
