Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Tranny fluid color???
Old Apr 8, 2005 | 08:55 PM
NOCturnalI30's Avatar
My tranny fluid is like a dark maroon sorta brownish red color. the car just today gave me a lil problem. When i floored it from first gear, when the car shifted to second gear it kinda lagged a lil before it would shift to second???? WTF does this mean. should i changed the tranny fluid?? should i do my VB upgrade with new tranny silinoids?? Im at a lost here please help
Old Apr 9, 2005 | 05:46 AM
2002 Maxima SE's Avatar
Sounds like it is time for a flush. Regular tranny fluid is clear red. How many miles since you last changed the ATF?
Old Apr 9, 2005 | 11:18 AM
i dont know if it has even been changed i bought it used. should i just do a lil drain and fil?
Old Apr 9, 2005 | 11:23 AM
Loe max's Avatar
There is also a TSB out for your year I30 for a slow 1-2shift which is fixed primarily by an updated TCM software.
Old Apr 9, 2005 | 01:29 PM
realllyyyyy where i need to knowwwwww
Old Apr 9, 2005 | 03:12 PM
yeah, you could do a drain and fill, but I think if I were you I would do a complete flush. I've been draining and filling every 20k miles since new. So my ATF fluid never really gets old. Draining and filling on a car of your age (what is the mileage?) may not be the best option.
Some will say you shouldn't drain and fill after a certain mileage if you aren't having problems, but I never understood that.
Old Apr 9, 2005 | 03:24 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
http://maxima.theowensfamily.com/tsb/NTB00-039a.pdf copy and paste that link for the tsb in pdf format.
Old Apr 9, 2005 | 08:14 PM
BigBadPooH's Avatar
how often should i change my tranny fluid?
Old Apr 9, 2005 | 09:13 PM
Loe max's Avatar
Its good preventative maintenance to change it about every 60K miles. But you should always check your fluids color.
Old Apr 9, 2005 | 09:50 PM
thanks guys, oh by the way should i have the tcm reseted or reprogramed? if so how much does it go for??
Old Apr 9, 2005 | 10:12 PM
NmexMAX's Avatar
dot dot dot ...
I'd say every 30k. But tehre is a TSB for the 1-2 shift slip that states to replace the VB, I just orderd a VB from Max tuning b/c mine was slipping on 1-2, but not the 2-3.
Old Apr 11, 2005 | 03:56 AM
so you think that will solve the problem there telling me to changed my silinoids as well and have everything done at once. I might just do all of that the vb mod and the silinoids.
Old Apr 11, 2005 | 06:00 AM
sloppymax's Avatar
i had slipping pretty early on in my the transmission's life. i had the tcm and solenoids replaced under warranty and all slipping went away. i also do a drain and refill with mobil 1 atf once a year and run a moderate sized tranny cooler.
Old Apr 11, 2005 | 01:54 PM
Love_00_Max's Avatar
Color of the fluid doesn't say anything about the viscosity, oxidation, stability, friction quality etc, Nissan trannys are brutal on fluids and a 30,000 mile OCI with dinos and 60,000 with syn is optimal. Oil analysis should say how far one can extend the OCI.
spencerwh1
Jun 30, 2016 05:44 AM
pktaske
May 6, 2016 07:49 AM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
