Mobil 5000 oil
Mobil 5000 oil
Anyone use this stuff yet? I got a coupon for 5 free quarts and have put it in. I hope its good stuff and should it hold up well?
Thanks,
Robert
oh and heres the link
http://www.mobiloil.com/USA-English/...lean_5000.aspx
Thanks,
Robert
if you race or floor it a lot. DONT BE A CHEAPSKATE AND GET SYNTHETIC!!!! and if you are gonna buy the 15,000 synthetic oil, i think its a waste of money since there are no oil filters that can run up to 15,000 miles, not that i know of anyways
Synthetics will "find" leaks so be prepared to see a few spots. I switched at 70K and my oil pressure sender unit became the source of a leak. This is due to the more uniform nature of synthetic oil molecules.
FYI, the 5K is dino oil. The 10K is a synthetic blend. Only the 15K is pure synthetic.
Originally Posted by MDeezy
I just dropped it in today after much needed change, so far so good, feels smooth but I also changed a dirty fuel filter. I'm will check it at 3K and see how dark the oil is.
Originally Posted by 2002 Maxima SE
What is the difference between the one with the silver top and the Extended Performance?
If you've read the Stickies about intervals you would have seen what most know.
You can (should) change the filter inbetween oil changes. Running Mobil 1 for 10,000 mile intervals? Change your filter at 5000.
Read the labels.
I don't know Mobil products well enough to recognize them by container description.
I did. The one with the silver top is the original synthetic and the EP is synthetic. Whats the difference? (aside from the marketing hype about it being "better").
Then why respond to a question you don't know the answer?
Because you quoted me, it's as though you directly asked me a question. I tried to be courteous and answer it with an honest answer. Obviously, you missed that.
The regular M1 is the same GF-4 M1 we've known for some time now, its also very similar to the GF-3 that we have known for just about ever, The GF-4 is thicker than the GF-3 and there are a few other changes.
The EP M1 is all new, it can supposedly go 15k due to its increased amounts of additives (both anti-wear and cleaning) for instance it has 37% more supersyn in it than the reg. M1 (Supersyn is Mobils additive package)
This oil is probally most comparable to amsoil. Im sure its a great oil however i dont trust it for that lond in my engine, however i might go 10 or 12.5k on it eventually.
I bought the 15k mile full syn only cause it's for either 15k miles or a whole year. I'll only put on maybe 6-8k miles in that year but I know the oil can last that long. With other oils it maybe a 7.5k mile oil but it only last 6 months so I'll have to change the oil two times instead of just once with the full syn. Also since the ful syn states NO SPECIAL OIL FILTER REQUIRED, why would I need to change the filter half way through, which I won't?
Originally Posted by DAVE Sz
...why would I need to change the filter half way through, which I won't?
I think you mean changing the filter but not the oil.
I understand that except the oil remains cleaner much longer and it protects better right? Then wouldn't filter be getting only a tiny bit dirty compared to dino oil anyway?
You are probably doing the right thing with the 15k oil I guess. Safe anyway.
But in reality, these maker's claims only hold on a good working engine. But any oil in a crap running engine and it will contaminate way before it's supposed to be changed. Not to say yours is like that. But the ONLY way to get an ACCURATE view of how you oil is doing is getting it analyzed. Until then, you are basicly just guessing.
I'll only put on maybe 6-8k miles in that year but I know the oil can last that long. . . . why would I need to change the filter half way through, which I won't?
If you use a good filter (PureOne, M1 etc) then you shouldnt have to change it. However i still would, $5 every 6 months is cheap insurance. If a bypass valve gets stuck open or somthing on regular 3000mile/3month oil its not to big of a deal but for a full year it is cause for concern.
Also during the year make sure you get this car out on the highway for good long drives, to allow it to get all cleaned up by the filter, burn off any water, and burn off any gas.
Originally Posted by NismoMax80
So, you missed the memo huh???
cause i mean when you take the filter off, wouldnt most of the oil drain outta the engine??
Originally Posted by Zero9890
how exactly do you change your filter with out changing the oil???
Originally Posted by Virus
Synthetics don't "find" leaks. They clean better than dino oils, so they clean clogged areas, therefore exposing problems that existed in the first place.
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
