Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Why does the dealer have to check AT Fluid?
Old Jul 12, 2005 | 10:30 AM
danted23's Avatar
I read the stickies and every other post that I could find 'manually' (I don't have the search option) but no post seems to address this. I have a 2004 SE 5-speed automatic and it's time for my 12,000 mile maintenance check. I have to check the AT Fluid this time. My manual says:
5-SPEED AUTOMATIC TRANSMISSION FLUID
When checking or replacement is required, we recommend your NISSAN dealer for servicing.
But explains how to check it if you have a 4-speed. Wouldn't it be the same for a 5-speed? I understand the 6-speed manual is probably different but I was surprised to see that I had to have the dealer do this.
Thanks in advance.
Old Jul 12, 2005 | 11:12 AM
Bobo's Avatar
That is nonsense. At 12,000 miles you don't even need to go to the dealer. Have you rotated the tires before? They should probably be rotated every 7,500 miles.
Most of what the dealer does is inspections? I take it you don't do work on the car yourself. Any oil change place should be able to check the ATF and most do a 21-pont inspection. Get them to check off that the ATF has been checked. Get an oil change and filter. Lastly keep the invoice stored away safely for warranty purposes.
Old Jul 12, 2005 | 11:54 AM
danted23's Avatar
So far I've done all the "work"
I agree that it's nonsense. I haven't been to the dealer and don't plan on it. I followed the tire rotation schedule and had them done by 7,500. I have been changing my oil/filter every 3K (starting when I bought the car).
I can do most (up to this point I have) of the inspections that the maintenance schedule requires. I was surprised to see the owner's manual explain how to check it for a 4-speed and then go onto say that a 5-speed owner must have the dealer check. I could see if it said 6-speed...
Old Jul 12, 2005 | 12:05 PM
Bobo's Avatar
As far as I can tell your warranty can not be voided by not going to the dealer for service. I'm not from the US, but I don't think you are compelled to get them to do the ATF inspection by law. You might want to confirm this by checking with a couple of dealerships, other than where you bought the car.
Old Jul 12, 2005 | 06:05 PM
UncleMax98's Avatar
Maybe the 5-speed auto transmission is sealed and has no dipstick?
Old Jul 13, 2005 | 10:20 AM
danted23's Avatar
You're right UncleMax98.
I just checked and there isn't a dipstick. I just *assumed* there was one.
sctludwig
Sep 1, 2022 01:32 PM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
