Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
synthetic blend question.
Old Aug 27, 2005 | 04:04 AM
HoldTight's Avatar
What is synthetic blend oils used for? Can you run them longer? are they better then dino? I was considering using it in my 100k mile civic today when I change oil today. Any thoughts?
HoldTight...
Old Sep 2, 2005 | 09:57 AM
o0godspeed0o's Avatar
Studies say theres no long term effect. However, Synthetic oil can run under harsh conditions and I believe last longer. I could be wrong. Most people are die hard Synthetic users and wont use anything else. I for one, use only Mobil 1 and their filters.
Old Sep 2, 2005 | 10:08 AM
Bobo's Avatar
Consider running AutoRX before switching to synthetic oil. See www.auto-rx.com
Apparently most synthetic blends only contain about 10% synthetic oil. I wouldn't waste money on them as they are more expensive than dino oil.
If you want to switch to synthetic and want to slow the transition, blend your own mix. Use say one quart of Mobil 1 and the rest whatever dino juice of the same weight you prefer, then check for leaks. If there are no leaks, perhaps increase the proportion of synthetic to dino at the next oil change, or make the leap to synthetic.
However, I would be inclined to run 2 AutoRX trials first and just switch to synthetic.
It will take about 6K to make the transition.
Old Sep 16, 2005 | 03:45 PM
Flutie7NFL's Avatar
I just had this conversation the other day. It seems like a product for those who aren't quite sure they want to make the switch. And one does wonder just what the ratio is. Good advice on brewing up your own if that is what you really want.
Old Oct 11, 2005 | 12:22 PM
DrKlop's Avatar
Driving is the next best thing
I don't think you can do that. (unless it was a joke)
Old Oct 11, 2005 | 12:24 PM
Jeff92se's Avatar
I'm needing a caw
Blend = waste of $.
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
pears
Sep 18, 2015 05:25 AM
pjgreek
Sep 9, 2015 09:30 PM
