Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
atf in a 5spd???
Old Sep 20, 2005 | 06:15 PM
ShadowMav's Avatar
atf in a 5spd???
i had my clutch changed like 2mths ago and i just changed the cv shafts (both sides) and red fluid came out.....atf?????...and our trannys use gear oil...right.....not to menton this is the first manual tranny ive owned......i should drain and refill with gear oil....right....would a synthetic work better????
Old Sep 20, 2005 | 06:27 PM
THT's Avatar
THT
Throbbing member
Not ATF...GL4 gear fluid. And yes, use a synthetic such as Amsoil or Redline.
Old Sep 20, 2005 | 06:36 PM
ShadowMav's Avatar
ok but would the atf hurt my tranny?
Old Sep 20, 2005 | 06:49 PM
THT's Avatar
THT
Throbbing member
Of course it will...
Old Sep 20, 2005 | 10:29 PM
joaquink's Avatar
¿Hablas Español?
Holy ****, who put the ATF in there?
Old Sep 21, 2005 | 10:39 AM
endus's Avatar
An atavistic endeavor...
Sweet Jesus man...you put ATF into your MT? Yea, you definitely DO need to use the proper lubricant for something like your TRANSMISSION. Come on dude...use your head.
I use Redline and it's great. MUCH better on cold mornings...night and day difference.
Old Sep 21, 2005 | 11:49 AM
ShadowMav's Avatar
no i didn't put it in there....im not a total retard....the guy who put in my clutch/pressure plate did i was like .....i just noticed it when i changed my cv shaft last week or the week before that
edit: im gonna change it tomorrow.....just a dumb question....why is synthetic better than reg gear oil?????know why it better for engine oil just don't know if it follows the same idea
Old Sep 21, 2005 | 12:10 PM
endus's Avatar
Ever come out to your car on a REALLY cold morning and it feels like the transmission is filled with slush when you go to shift? With synthetic, that never happens.
Old Sep 21, 2005 | 07:31 PM
chinaonnitrous1's Avatar
Umm.......for 1991 Celicas in a 5spd....ATF was the call for fluid in the manual trans.
Old Sep 21, 2005 | 07:41 PM
THT's Avatar
THT
Throbbing member
Okay, but that's a 1991 Toyota Celica. The car in question though is a 1995 Nissan Maxima...slight difference.
Old Sep 22, 2005 | 12:13 AM
duh! just saying for the record.....that ATF...sometimes makes its way into manual trans.....for some stupid reason.....
hell even toyota retracted that idea in 1992.
Old Sep 22, 2005 | 04:11 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
there is a prominent member of the board that used atf in his 6spd. lets see if he defends it or not.
Old Sep 22, 2005 | 01:14 PM
ShadowMav's Avatar
ok does the differential use the same gear oil as the tranny or is it sperate fluid....remember i pulled out the cv shaft when the red fluid came out
Old Oct 7, 2005 | 09:20 AM
Phoenix's Avatar
Lives in a Maxima
My MGB recommends 20W50 in the gearbox and the rear diff... as well as the engine.
So it all depends on what it was designed for. But the MG's british so take that for what you will.
Old Oct 7, 2005 | 09:50 AM
Bobo's Avatar
Phone the guy up who did the work and find out precisely what he put in the transaxle!
Just don't speculate on what it is. You may have to do nothing.
I had my transaxle fluid replaced in February with Quaker State GL4 75w90 gear oil. It is regular gear oil, not synthetic, and was amber/honey color. The OEM fluid that came out was black and probably should have been changed sooner.
If, in fact, you have to change the gear oil, stick with GL4 in a 75w90 or 80w90. Do NOT use GL5.
If you decide to switch to synthetic, do what someone above suggested and use, Redline or Amsoil. However, make sure it meets GL4 specs. Evidently GL5 will/may screw up any brass bushings in the transmission and harm the synchromesh.
ef9
Oct 4, 2015 08:43 AM
220k+ A32
Sep 11, 2015 02:18 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
mclasser
Aug 23, 2015 09:32 PM
