Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
brake calipers
Old Sep 29, 2005 | 05:14 PM
roll4life's Avatar
brake calipers
if the caliper doesnt grip the whole rotor can this be an issue of a piston thats not fully compressed..and should i rent the special tool from an auto store and compress them? my rear rotors are pretty rusted everywhere except the middle where the calipers actually squeeze the pads enough to touch the entire rotor
Old Sep 29, 2005 | 06:50 PM
aussie983's Avatar
Wrong section. And no, you only need need nose pliers to turn them back into place. Make sure the X on the piston lines up so that it faces a certain way described on a shop manaul (i dont have the pic with me so i dont remember how it goes).
Old Sep 29, 2005 | 07:26 PM
roll4life's Avatar
can a mod please move this to the right section? i really need this answered
Old Sep 29, 2005 | 07:37 PM
Bobo's Avatar
You are better off with the tool. If your caliper is seized you are better off replacing both rears. You are also better off not resurfacing rotors as they are thin to begin with. Replace rotors rather than machine them.
Old Sep 29, 2005 | 07:40 PM
roll4life's Avatar
replace the calipers? that would be expensive
Old Oct 8, 2005 | 06:58 PM
bhmax16's Avatar
He's right though, seized caliper = replace BOTH calipers. They're on a hydraulic system and it won't work correctly otherwise. Your only other option is to try to save the caliper piston by blowing it out of the caliper with a blowgun and cleaning all the corrosion off of it then lubing and pressing it back into the caliper. It's more work than it's worth though and sometimes you can't blow the piston out
Old Oct 8, 2005 | 11:15 PM
dabooki's Avatar
rotors are like 20 bucks aren't they. caliper maybe 60 or so for one. the caliper tool is like 6 or 7 i bought one the other day at auto zone. easy job just bleed the lines correctly
Old Oct 8, 2005 | 11:16 PM
dabooki's Avatar
why won't it work correctly only replacing one caliper? aren't all the lines independent for each wheel?
Old Oct 9, 2005 | 07:21 AM
bhmax16's Avatar
You'll have unequal braking because the new caliper is going to operate more smoothly than the older one, even if the older one is still in good working order. I work in a shop so just take my word for it and do both calipers if you can't save your other one.
Dabooki - Rotors are maybe $20 each if you get super cheap ones from autozone or something that will warp on you in no time. Brakes are one part of your car you should never go cheap on. I spent $245 for new front pads and slotted rotors for my max a few weeks ago and let me tell you there is a difference (and I'll be doing stainless lines next). My braking is ultra quiet and I have yet to hear a squeal come from them. They also bite a bit harder and don't dust anymore than OEM pads (I got Axxis Ultimate pads with Rotora slotted rotors) per Steve at SCO's recommendation. Fronts provide the majority of your braking power which is why they wear much more quickly than rear brakes. For the rears I'd stick with Brembo blanks and the pad of your choice. Calipers are much more than $60 though unless you maybe do a core exchange through autozone
roll4life - if you can afford to have a few days downtime on your max and want to send me your caliper I'll gladly rebuild it for you free of charge all you'll have to pay is shipping. Let me know
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
