Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Blackstone results!!! Need help!!!
Old Oct 13, 2005 | 06:38 AM
2k2MerlotSE's Avatar
JUVIN's ride
I received my results but I am not sure what any of it means... The TBN is 4.8 and the lead is 10 and should be a 5. There are some other higher numbers but the lead is the only one in bold.
They did not tell me if I could extend my drain interval. For the test I ran amsoil 0w 30 with the nissan OEM filter. I changed the filter at 3k miles and at 6k miles I took the sample and sent it in.
Now I'm running the same oil but I'm using the amsoil SDF 13 filter. The car hit 5k miles on the current setup and I'm not sure if I should send another 6k mile sample to see the results..
Anyones input would be greatly appriciatied. Here is a copy of the test results.
http://community.webshots.com/myphot...ecurity=PrOAkK
thanks for the input.
Old Oct 13, 2005 | 06:47 AM
Bobo's Avatar
Post your results on www.bobistheoilguy.com in the Used Oil Analysis Forum and you will get some incisive input. Also get back to Blackstone and ask them to interpret the data and ask what the ideal OCI would be.
Old Oct 13, 2005 | 07:38 AM
JUVIN's ride
I just registered. once I am approved I will post my results on there.
thanks for the info
Old Oct 17, 2005 | 05:03 PM
venom32225's Avatar
post them as soon as you can!!!
Old Oct 20, 2005 | 09:53 AM
johnny2kgle's Avatar
The VQ engine seems to show 10+ ppm lead count in many reports that I have seen.
You might consider using the interpretation services of Terry Dyson for a small fee of $20. There is a Blackstone Analysis TBN/Dyson commentary package available for $40 that you should consider for your next UOA.
http://www.blackstone-labs.com/dyson_analysis.html
Old Oct 20, 2005 | 10:25 AM
sky jumper
2k2MerlotSE - are you still reading this thread? I'd rather not post my thoughts on your UOA on BITOG, although I have read the thread you have going there. I normally wouldn't contradict Terry Dyson, but I don't think his advice on AutoRX or Fuel Power have anything to do with your elevated lead - I think it is just his general care care advice. AutoRX is for cleaning dirty engines - your engine is still young and you have been using Amsoil so I doubt its dirty at all. it wouldn't hurt for you to use it, but don't expect it to decrease your lead.
however - Terry's advice on air filtration is probably right on. i would try an OEM nissan air filter, or a good aftermarket (such as wix) instead of the Amsoil air filter. i'm using OEM right now and had very low Si and Pb in my last UOA. I don't really know much about Amsoil products, so it's hard for me to critique them, I can only share my experiences with what I have used.
Old Oct 20, 2005 | 03:55 PM
JUVIN's ride
hey sky- sorry I haven't been reading.. I am going to put in the OEM air filter and for the he!! of if change the PCV. I did order the auto rx and fuel cleaner. Shoud I just go ahead and do it anyway?
I posted on BITOG what it is I am going to doing for the entire process..any advice would be greatly appriciated..
thanks again.
Old Oct 21, 2005 | 12:00 PM
sky jumper
yeah go ahead with the ARX and FP. it wont hurt at all. just follow the instructions carefully. do another UOA after 5k miles or so on your post ARX OCI (e.g. not the clean phase, not the rinse phase, but 5k miles after you put in new oil after the rinse phase -- make sense?)
Old Oct 22, 2005 | 08:04 AM
JUVIN's ride
Yes it does...once I receive the stuff I will start and kepp everyone posted.
thanks again
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
