Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Power steering fluid replacement
Old Oct 20, 2005 | 11:56 AM
Bobo's Avatar
I decided to use the turkey baster method for removing and replacing power steering fluid from the reservoir.
I bought a litre (1,000 ml) of Dextron III ATF from Canadian Tire (house brand) and replaced about 185 ml.
Does anyone know how much volume the reservoir and system contains?
Over the course of the next week or so, should I repeat this process say five times until the entire litre has been used up, or is that overkill?
Old Oct 20, 2005 | 12:04 PM
kcryan's Avatar
do i swap every month or so for a while, thats what i do. its real quick and my ps seems happy
Old Oct 20, 2005 | 12:09 PM
Bobo's Avatar
U da man, kcryan! Maybe, I'll try that. As you can see, I am rather **** about the Maxima.
Who knows, one day I might even buy new spark plugs, lol!
Old Oct 20, 2005 | 03:58 PM
kbmaxima's Avatar
i can't understand how u have 4,000+ posts and JUST changing the PS fluid
Old Oct 20, 2005 | 03:59 PM
crazy97's Avatar
Yeah right!
Old Oct 20, 2005 | 04:17 PM
Bobo's Avatar
I had the power steering profesionally flushed in May 2004, but I didn't watch the process.
I took my car into a new Lubeworld the other day and got the guy to replace my fuel filter. He cleaned the throttle body at the same time and only charged me Cdn$35 all in (US$30).
In the interests of trying to sell me something, he stuck his finger in my power steering reservoir and told me I needed to change my PS fluid to which I replied I just did it last year and he responded that it should be changed every year. Suffice it to say, I did not rise to the bait.
Today, I sucked some PS fluid out with a baster and put it in a measuring cup. I poured an equal volume of new Dextron III into another measuring cup. There was a noticeable difference in color with the older fluid being darker. I dumped the new ATF fluid (about 6 ounces or so) into the reservoir.
I intend to continue this approach for awhile and am merely asking how much more of the ATF I should add.
The PS fluid had never been replaced prior to June 2004 and the stealership did not comment on it when I had the car there in May 2004. At the time of changing the PS fluid, more than 10.5 years had elapsed since I bought the car new, but it only had about 52K on it.
I now plan on replacing the PS fluid periodically as its easy to do.
QUOTE=kbmaxima]i can't understand how u have 4,000+ posts and JUST changing the PS fluid[/QUOTE]
Old Oct 20, 2005 | 06:44 PM
Curt Deiner's Avatar
I pulled the low pressure return line off the reservoir, put it in a bucket, plugged the fitting the line came off, filled reservoir with Mobil 1 ATF, put the wife in the driver seat to start the car and turn the wheel back and forth lock to lock while I poured more ATF in the reservoir. Had to have her stop the car once so I could keep up.
vingodine
45
May 21, 2016 12:46 PM
02PearlSE
Oct 7, 2015 02:12 AM
maxinout93
Aug 20, 2015 02:17 AM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
