00 maxima, brake fluid + coolant
I seem to have two brake fluid containers, one yellow one black.
The black one is slightly bellow minimum.
Which kind of brake fluid should I fill it with?
Also, My coolant container is almost empty.
What kind of coolant should I use?
thanks.
thanks.
I suspect the one below minimum is your power steering reservoir. Do not put brake fluid in that reservoir.
Do you have coolant in your radiator? If its full, I wouldn't worry about the coolant container as it is just for overflow. When was the coolant last flushed? It should be flushed at 30K and again at 60K.
Originally Posted by godlyone
There is actually a fly in there lol!
LMFAO!!Maybe u can take a picture and post it with the things you are referring to circled. Or explain which container you are talking about and the apporximate location.
MAXSE5SPD
Aug 23, 2015 12:06 PM
Mrbizness1
Aug 18, 2015 08:43 PM
