Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Thinking to change OIL...Any suggestions?
Old Mar 4, 2006 | 11:55 PM
05MAXIJJ's Avatar
I am at 30000 miles in my 6th Gen maxima...I like to drive fast and drive alot..
What is a good synthetic old to get most power and helps the HEAT from fast and excesssive driving?
Is Mobil 1 sythentic good?
Which one do i use? 5w-30 10w-30? Thanks..
Old Mar 5, 2006 | 01:54 AM
steven88's Avatar
Need A Light?
VQ35 loves German Castrol Syntec 0w-30 .......its a thick 30wt oil at operating temperatures n it doesn't break down as much as mobil1....according to the guys at bitog forums...
You should try it out...VQ35s tend to love thicker 30wt oils...some engines don't though. be wary of that...
Old Mar 5, 2006 | 06:11 AM
Maxima880's Avatar
Unless your wealthy, cost will be a factor with synthetic. See what's available at a discount retailer, (Wal Mart), in a gallon jug. Mobil 1 for sure, Castrol maybe, maybe not.
Old Mar 5, 2006 | 08:43 AM
JwaxMax99's Avatar
I keep reading in here about this German Castrol 0W-30. Is there a place that normally stocks this oil?
Old Mar 5, 2006 | 10:04 AM
steven88's Avatar
Need A Light?
Autozone or Advanced Auto chains will stock these oils....make sure when you go buy it, read on the back and it will say Made in Germany (all others will say made in USA)
Old Mar 5, 2006 | 05:40 PM
kcryan's Avatar
GC is hard to beat, but its a tad trickey to find, you will be more than fine with good old Mobil One 5w-30, i wouldnt use the EP version, its more money, thinner, and for other reasons i just really dont like it as much as its cheaper brother.
Although GC is always a good choice, M1 is easier and hard to beat.
Good luck.
Ohh and id reccomend a M1 filter or a PureOne filter.
Old Mar 5, 2006 | 11:17 PM
steven88's Avatar
Need A Light?
I just changed to GC Green on my VQ35...man its so smooth at idle I love it! I will keep you guys posted on my gas mileage....i heard GC tends to suck up more miles since it is a thicker oil
Old Mar 6, 2006 | 02:09 PM
kcryan's Avatar
True, might not be noticible really though, and your engine wont mind using a lttle extra gas, for the protection it will be getting
Old Mar 7, 2006 | 04:50 PM
05MAXIJJ's Avatar
Is Castrol Synthentic same thing as German castrol?...Thanks
Old Mar 7, 2006 | 06:59 PM
steven88's Avatar
Need A Light?
No it's not.....Castrol SYntec 5w-30, 10w-30, 20w-50, 5w-50 and pretty much all weights are made in the USA
0w-30 on the other hand is made in germany...
Old Mar 14, 2006 | 08:19 AM
shurik's Avatar
Mobil 1 synthetic???
Yup I guess I'll switch to Mobil 1 syntheric, 5w-30 as well. Right now I use Royal Purple synthetic, no problems with it but I heard Royal Purple is just not as good as Mobil with price, milege and reliability. Well let's try and find out. I guess I'll use M1 filter as well.
BTW sorry for asking this but how many bottles of oil are we actually suppose to use for our VQ35, should be 5 right? I don't have manual that's why I'm asking.
Ohhh yeah Steven, how do you know so much about oils, and you know what you car likes and dislikes!!! Man, I like that... it's like you and your car =1. Just like 1+1=1 You probably the only one who knows so much about all that.
Old Mar 14, 2006 | 09:02 AM
Bobo's Avatar
I switched to synthetic oil for the first time 5 weeks ago. I'm running Esso XD3 Extra, 0w30, PAO, full synthetic. I switched following an AutoRX clean and rinse and can notice no discernible difference in fuel economy with this heavier 30 weight oil.
This product is not available in the United States. It is gaining rave reviews on BITOG and is preferred over Mobil 1 on the basis of UOAs and VOAs.
Old Mar 14, 2006 | 09:29 AM
steven88's Avatar
Need A Light?
Alex - lol, I'm not that knowledgeable....i just did a little research here and there....give german castrol a try alex....the vq35 specs for a thicker oil and thats what german castrol exactly is! in the european FSM, it calls for 10w-40 stock, and 20w-50 for upgraded....GC is actually a thick 30wt, think 40wt....the vq35 loves thicker oils! and mobil1 (especially their EP line) is too thin for the vq35 if u ask me...
give it a shot...just go to your nearest autozone chain and look for 0w-30 GC...it will say on the back made in germany....all the other weights will say made in USA
Old Mar 14, 2006 | 10:45 AM
steven88's Avatar
Need A Light?
I use the nissan 9e000 filter off a 95 maxima...the stock 65F00 2k2 maxima filter blows donkey *****!
Old Mar 14, 2006 | 02:48 PM
NYC TAR's Avatar
I have used the Castro (GC) 0-30 for about 1/2 year already. For the past 1/2 year I haven't burn a drop of oil compare with M1 5-30 I've already burn at least half to one quart of oil already. PLUS engine is really smooth at idle and at hi rev.
Old Mar 15, 2006 | 09:06 AM
shurik's Avatar
So I guess using GC 0-30 should be pretty good, huh? How many quarts did you use to put in with mobil, and how much with GC? About 5 right?
Old Mar 15, 2006 | 09:52 AM
steven88's Avatar
Need A Light?
I put in 4.75....for some reason, when I drain my oil and pour the factory listed 4.25....I'm coming up short on the dipstick....so I add in another half a quart and that brings up the level....
Old Mar 16, 2006 | 04:42 PM
NYC TAR's Avatar
about 4.35 qt all the time
Old Mar 22, 2006 | 08:17 AM
russianguy's Avatar
yea 5w30 is the shiz
flu2000
22
Sep 2, 2015 07:29 AM
max1029
Aug 26, 2015 09:51 AM
acw
Aug 7, 2015 04:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
