Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
need to confirm
Old Mar 13, 2006 | 08:28 PM
DrKlop's Avatar
Driving is the next best thing
need to confirm
Putting too much oil into the crankcase will not cost any problems, right?
I put 1/5 of a quart more than I was supposed to and just wanted to confirm that it's fine.
Old Mar 13, 2006 | 11:13 PM
SilverMax_04's Avatar
Not a good move, but at 1/5 of a quart, not likely to cause any big problems.
If you pull the oil drain plug, you will probably take too much out before you get the plug back in the pan again. I would check the dip stick to see how high the oil level is above the top mark on the stick. You can see if the level is about 1/5 of whatever the distance is between the two marks on the dip stick. If it is more, I would try to drain some off to get it down.
Old Mar 13, 2006 | 11:31 PM
steven88's Avatar
Need A Light?
you can try loosening the oil filter and oil will start dripping out...
Old Mar 13, 2006 | 11:49 PM
DrKlop's Avatar
As fanny as it sounds, i can't read the damn dipstick in our cars. In all other cars there's a clear boundary between oil and no oil. In maxima, every time I take it out to check oil level the first 5 inches are covered with oil even after I wipe it and check it again.
What problems can it cause?
Old Mar 14, 2006 | 12:05 AM
Try reading the dip stick in the morning (after the engine has been sitting for a number of hours). You should be able to better read the level of the oil.
Old Mar 14, 2006 | 08:33 AM
DrKlop's Avatar
I finally managed to see the oil level, and it's slightly above the letter 'H' Sort of like this:
LxxxxH] - oil covers everything below the square bracket.
Old Mar 14, 2006 | 08:38 AM
You should be fine with this. I would not worry.
Old Mar 14, 2006 | 08:46 AM
DrKlop's Avatar
whooo.... this sounds better
BTW: the car is parked on a slight inclined and faces downhill and this is the rinse cycle of AutoRX. I'm still fine, right?
Old Mar 14, 2006 | 08:56 AM
Bobo's Avatar
Don't sweat the small stuff, you'll be just fine!
Old Mar 28, 2006 | 04:46 PM
spiromax's Avatar
Seoul Man
Just a tiny bit over is not a problem. If you overfill too much, though, you could do some damage.
Old Apr 5, 2006 | 04:57 PM
motorheadwannab's Avatar
Just curious, what can it do to your engine?
Old Apr 5, 2006 | 05:34 PM
spiromax's Avatar
Seoul Man
Stolen from the guys on the Car Talk radio show:
"A word of caution: Be careful not to overfill your car's crankcase with oil. If you put in too much oil, the engine's crankshaft can actually come in contact with the oil. And because the crankshaft is turning at several thousand revolutions per minute, it can quickly whip your oil into a froth — like the steamed milk that sits on the top of a cappuccino. Why is that bad? Well, the oil pump can't pump froth very well, and as a result, it can't get oil to the parts of the engine that need lubrication. The result ... a hefty boat payment to your mechanic."
Old Apr 5, 2006 | 09:12 PM
konak85's Avatar
Its best to keep it right in the middle between the two points but 1/5 more won't do any harm.
Old Apr 6, 2006 | 09:55 PM
carsarecool's Avatar
I thought the bottom of the crank was sitting in oil? Or the pump just sprays oil on the crank and bearings and everything? Sorry if that sounds dumb i dont know a ton about engine internals, well im trying to learn
James92SE
142
Jan 2, 2024 09:23 AM
AaronL
Nov 15, 2020 11:52 AM
9aj9
Apr 5, 2020 12:11 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Vistance
Sep 17, 2015 05:17 AM
