Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Q: Changed oil mobil 1 3 1/2 qts 5w30 and 1 qt 10w30 accidently
Old Jun 30, 2006 | 11:34 PM
TopSpeedNY's Avatar
Just changed my oil today with pureone filter and accidently used 10w30 is that fine with 3 1/2 quarts i believe shouldnt be a problem guys any suggesting.
Mike
Old Jul 1, 2006 | 12:23 AM
Jibberish18's Avatar
No problem whatsoever. Next time try a Kamikaze mix. Little bit of 5w-20 here, bit of 5W-30 there, a shot of 10W-30 to top off and bam!
What I'm saying is, it won't make a difference.
Old Jul 1, 2006 | 11:55 AM
Torkaholic's Avatar
No problem at all, especially since both of the oils are same-brand and both viscosities are Nissan-approved for the VQ. Give this not another thought.
Old Jul 1, 2006 | 01:06 PM
TopSpeedNY's Avatar
thank you so much i was a bit worried btw the car starts quicker rpms are steady as well thanks again.
Mike
Old Jul 1, 2006 | 10:06 PM
SilverMax_04's Avatar
Given my changing opinions about oil weight, I mix my Mobil 1 oil weights every time I change oil.
- I had quite a bit of 10W30 weight Mobil 1 because that was the weight that my previous car required (it was totaled unexpectedly in 03).
- When I could get a good price more recently on Mobil 1, I bought some 5W30 -- because that was what Nissan recommended in the manual.
- Then I found out that in Europe, Nissan recommends 10W30 for their VQ 3.5 engines. It provides better high temperature protection is my assumption for this European recommendation. The US recommendation of a lighter weight oil is so they can claim a very slightly higher EPA mileage rating.
So to use both weights of oil that I have in stock, I uses only one qt of 5W30 when I change oil for the summer and 2 quarts of 5W30 when I change oil for the winter. Have had no problems and don't expect any. When all of the existing 5W30 is used, I will stick to 10W30 year round.
Old Jul 2, 2006 | 01:34 AM
TopSpeedNY's Avatar
oh so there isn't any problem mixing since they are both good quality oils and synthetic cool.
Old Jul 2, 2006 | 11:44 PM
It is also appropriate because the only difference in the two oils is the weight (10W30 vs 5W30). They are both the same Mobil 1 oil with the same additives and synthetic base stocks -- except for those additives and stocks that control weight.
Old Jul 6, 2006 | 07:09 PM
Da_Shatterer's Avatar
I needa try an oil cocktail next time I go i n for an oil change lol
97_GXE
20
Sep 17, 2015 08:12 PM
Jay556
Sep 12, 2015 05:50 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
